I'm not sure if this is a bug but I'm pulling it as this shader is sclavel's edit. I'm not getting the cubes resizing in vdj.
Not sure I should, but I guess I should
https://www.shadertoy.com/view/MsdBR8 | view on shadertoy | copy link
Posted Sat 11 May 19 @ 10:22 am
Another one, even less sure about this
https://www.shadertoy.com/view/ldVBDD | view on shadertoy | copy link
It's supposed to sync with system time, but in vdj it starts at 00:00:00
https://www.shadertoy.com/view/ldVBDD | view on shadertoy | copy link It's supposed to sync with system time, but in vdj it starts at 00:00:00
Posted Sat 11 May 19 @ 10:52 am
I can't say it's a bug for sure but I'm really suspecting sound reactive shaders aren't working right with vdj
This one responds very differently between shadertoy and inside vdj
https://www.shadertoy.com/view/Wll3Df | view on shadertoy | copy link
Posted Wed 15 May 19 @ 2:21 pm
https://www.shadertoy.com/view/Wll3Df | view on shadertoy | copy link The far left side seems to move far less, where as the the other 2/3rds are kicking off big time
Posted Wed 15 May 19 @ 2:43 pm
https://www.shadertoy.com/view/MdVSWG
looking at this one, on shadertoy it's centred on bass, in vdj there's a massive dip in the centre.
Like vdj isn't getting the freq right, or maybe endianess is wrong [blind guess]
Posted Wed 15 May 19 @ 2:48 pm
Another sclavel edit, this one is a bit too excitable in vdj
https://www.shadertoy.com/view/ldcfWH | view on shadertoy | copy link
Posted Wed 15 May 19 @ 3:08 pm
Weirdly enough I kinda like the dip as it's symmetrical enough to get away with it
Posted Wed 15 May 19 @ 3:22 pm
I know what you're saying, that's a day zero shader and assumed that's the way it was meant to be.
I might try re-edit that one if this is a confirmed bug.
Posted Wed 15 May 19 @ 3:26 pm
can you see if you can get the clock one to work?
Posted Wed 15 May 19 @ 4:00 pm
I know it would be nice to have [NYE] but there's nothing I can do, my guess is vdj isn't giving iDate to the shader at all so it takes the variable as zero.
Posted Wed 15 May 19 @ 4:19 pm
Question guys
I'm missing the transparent button on the shader. It was there one minute, and after restarting VDJ it was gone
I'm on 8.3 B4918
I'm on 8.3 B4918
Posted Fri 17 May 19 @ 4:55 pm
transparent dial is not available as audioOnlyVisual.
Posted Sat 18 May 19 @ 8:33 am
If running as audioOnlyVisual, it means behind the shader would be black, so transparency would be pretty useless.
Posted Sat 18 May 19 @ 9:25 am
Any comment on the stuff I pulled.
Posted Sat 18 May 19 @ 10:21 am
Got it now!!!!
Thanx
Thanx
Posted Sat 18 May 19 @ 1:09 pm
The Video Source drop down is the same as audio Only vis.
Select (Transitions) from the menu or load a video, then select shader from the video effect drop down under 'overlays'
Posted Sat 18 May 19 @ 1:12 pm
Why don't the shaders mentioned above work correctly in VDJ?
Posted Sat 18 May 19 @ 3:45 pm
Thanx again guys
Much Respect!!!!!!
Shader (Transparent) combined with Milkdrop, (as AudioOnly) totally, totally Awesome!!!!!!!
Much Respect!!!!!!
Posted Sat 18 May 19 @ 4:39 pm
All the above mentioned shaders are working on my MacBook like there supposed to EXCEPT the clock, it always starts at zero.
Posted Sat 18 May 19 @ 7:06 pm
@tsi,
the first one, do the cubes change size with the music?
the eq bar graph [the one that won't show in the forum for some reason] does it actually look like it's following the sound or does it look a bit random?
Posted Sat 18 May 19 @ 7:47 pm
