Is there a way to change the color of the check
mark next to the Harmonics Key difference.
Posted Tue 09 Apr 19 @ 4:27 pm
No.
What change would you like to do ?
Posted Tue 09 Apr 19 @ 6:38 pm
I Forgot to mention: The Matching
Harmonic key color is very faint on
for me.
Makes it difficult to tell which song is highlighted.
Hope this make sense.
for me.
Posted Tue 09 Apr 19 @ 9:41 pm
Fully compatible checkmark is plain white. If that's very faint, then any other color will be even more faint...
Compatible within one semitone is 66% white if I remember correctly. Getting that one brighter will make it more difficult to tell if the track is fully compatible or needs one semitone change...
Posted Wed 10 Apr 19 @ 6:55 am
Thanks.
Mine appear almost the same, that is
why I thought there was a way to change the
color.
color.
Posted Wed 10 Apr 19 @ 3:25 pm
Perhaps you should check your screen settings then ?
Try to increase contrast or gamma and afterwards adjust brightness accordingly.
Posted Wed 10 Apr 19 @ 8:51 pm
Again thanks.That unfortunately did not help.
Much appreciateed.
Much appreciateed.
Posted Wed 10 Apr 19 @ 8:56 pm
