kalispera , osx 10.9.5 ssd 16gb ram late 2012 {v8.3 b4514}
kata kairous eixa pola 8emata me to virtual epaiza me ddj rr h me cdj 2000 ape8eias xwreis na mesolabei karta hxou ekswteriki , to problhma palia htane oti kata thn diarkeia tou set 8a ekane ena kopsimo 2 sec kai 8a epaize pali olo to brady xwris problhma ... me tin ddj rr sumbainei akoma alla sta cdj2000 to problhma ekane anabathmisi kai pleon kleini to virtual mono tou gia 5 sec kai anoigei pali kai sunexizei paizei to tragoudi exwntas xasei ta setting ton cdj 2000..
exw dei driver eixa kanei kai ticket exw steilei log report sto parelthon den bre8ike akrh ... kalodia usb exw allaksei para poles fores kai den kserw pragmatika ti allo na kanw.... den anebazei cpu ... gnwrizw oti yparxoune neoteres ekdoseis build alla den einai lush auto.. 1 xrono taleporoume me auth thn istoria kanw update mporei na ftiaksei gia kana 2 bdomades e meta pali ta idia kai aplos prospa8w na menw sthn pio sta8eri version... tha ithela tin boithia sas an gnwrizei kapoios kati... sas parathetw kai ena meros tou x8esinou log report an mporesei kapoios na katalabei kati (21:49 ekane to problima), ola auta sumbainoune eitai to wifi einai energopoihmeno eite oxi... me sumbouleusan sta ticket na to exw anoixto mhpws tous paei kana crash report kai broune akrh
Posted Mon 18 Mar 19 @ 2:03 pm
21:49] USB MIDI device: vid:0x8087 pid:0x0024 usbName: vendorName: serialNumber:
[21:49] USB MIDI device: vid:0x8087 pid:0x0024 usbName: vendorName: serialNumber:
[21:49] USB MIDI device: vid:0x0424 pid:0x2513 usbName: vendorName: serialNumber:
[21:49] USB MIDI device: vid:0x05AC pid:0x8242 usbName:IR Receiver vendorName:Apple Computer, Inc. serialNumber:
[21:49] USB MIDI device: vid:0x08E4 pid:0x014A usbName:PIONEER CDJ-2000 vendorName:PIONEER Corporation. serialNumber:
[21:49] Midi in device detected: \\?\usb#VID_08E4&PID_014A/337641472 (port:)
--- 2019/03/17 - 21:49 (4514)
[21:49] Audio device found: name:Built-in Microph hardwareID:"55"
[21:49] Audio device found: name:Built-in Output hardwareID:"47"
[21:49] Audio device found: name:PIONEER CDJ-2000 vid="0x08E4" pid="0x014A" hardwareID:"64"
[21:49] Audio device found: name:PIONEER CDJ-2000 vid="0x08E4" pid="0x014A" hardwareID:"62"
[21:49] Audio device found: name:Pioneer CDJ/XDJ hardwareID:"66"
[21:49] MIDI Device Identifying: \\?\usb#VID_08E4&PID_014A/337641472 (in:0 out:-1)
[21:49] MIDI Device Identified by PID/VID: \\?\usb#VID_08E4&PID_014A/337641472 : Pioneer CDJ-2000
[21:49] MIDI Device Identifying: \\?\usb#VID_08E4&PID_014A/337641472 (in:1 out:-1)
[21:49] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_0253/488124416
[21:49] HID Device found, looking for definition. \\?\hid#VID_05AC&PID_8242/488120320
[21:49] HID Device found, looking for definition. \\?\hid#VID_08E4&PID_014A/337641472
[21:49] Found definition for Pioneer CDJ-2000
[21:49] HID Device found, looking for definition. \\?\hid#VID_08E4&PID_014A/336592896
[21:49] HID Device found, looking for definition. \\?\hid#VID_0000&PID_0000/0
[21:49] Assigned Pioneer CDJ-2000, type:2, index:1
[21:49] Assigned Pioneer CDJ-2000, type:2, index:2
[21:50] USB MIDI device: vid:0x8087 pid:0x0024 usbName: vendorName: serialNumber:
[21:50] USB MIDI device: vid:0x0424 pid:0x2513 usbName: vendorName: serialNumber:
[21:50] USB MIDI device: vid:0x05AC pid:0x8242 usbName:IR Receiver vendorName:Apple Computer, Inc. serialNumber:
Μάλλον δεν γνωρίζετε κατι.... Να δοκιμάσω νέοτερη έκδοση OS X ;; Πια θεωρείται πιο αξιόπιστη ;; Κάποιος χρήστης μακ μπορεί να βοηθήσει;;;
Να ενημερώσω ότι το database του βιρτουαλ έχω περίπου 130.000 τραγούδια μήπως είναι αυτό ένα θέμα ;;; Υπάρχει κάποιο add on να το ελέγξει για σφάλματα πέρα από το remove missing file(κάπως Έτσι λέγετε δεν θυμάμαι ακριβός ) που κάνω μέσα από το βιρτουαλ ;;
Posted Wed 20 Mar 19 @ 11:17 pm
Όχι η βάση δεδομένων δεν παίζει ρόλο.
Αυτό που ίσως παίζει ρόλο είναι αν π εξωτερικός δίσκος μπαίνει σε κατάσταση ύπνου, οπότε όταν ξυπνάει καθυστερεί όλο το σύστημα.
Τέλος όσον αφορά το MAC OS εμείς προτείνουμε πάντα την τελευταία έκδοση.
Σε Sierra και High Sierra που ξέρω 2 συναδέλφους που δουλεύουν CDJ2000NXS και NXS2 δεν έχουν κάποιο πρόβλημα.
Βέβαια το MAC σου είναι λίγο παλιό (σχεδόν επταετίας) αλλά με βάση τα specs που αναφέρεις δεν νομίζω να έχει πρόβλημα με Sierra/High Sierra.
Αν κάνεις αναβάθμιση πάντως θα σου πρότεινα 'clean install ' πάντως και όχι αναβάθμιση.
Σε πολλές περιπτώσεις σε MAC πού είχαν θέματα βοήθησε.
Posted Wed 20 Mar 19 @ 11:53 pm
Καλησπέρα , έχω έναν ssd 256gb μόνο λειτουργικό και βιρτουαλ και στην θέση του cdrom έχω βάλει πλαίσιο και έχω τοποθέτηση δεύτερο σκληρό δίσκο 2tb με όλη την μουσική μου το έχω τσεκάρει δεν μπαίνει σε κατάσταση ύπνου ο σκληρος, αυτός είναι και ο κύριος λόγος που δεν έχω πάει σε νεότερο μοντέλο καο απλά αναβαθμησα στο μέγιστο αυτό που είχα ... τα νεότερα μοντέλα δεν εχουνε cdrom...
ωραία θα περάσω αύριο σιερα και από Δευτέρα θα ενημερώσω πως πήγε
Posted Thu 21 Mar 19 @ 12:06 am
Phantom δεν ξέρω αν έχεις πρόσβαση αλλά θα μπορούσες να δεις αν έστειλε κάποιο crash report το Σάββατο η την Κυριακή ;;; Ήμουνα με ανοιχτό WiFi όταν έγινε αυτό
Posted Thu 21 Mar 19 @ 12:09 am
Το πιο πρόσφατο crash log σου είναι από 1 Σεπτεμβρίου 2018, οπότε θεωρώ οτι είναι άσχετο.
Posted Thu 21 Mar 19 @ 7:24 am
perasa sierra alla otan anoiksa to virtual deksia apo to search mou grafei renaming kai to grafei gia kana 2wro twra.. mou to eixe bgalei kai sto parelthon alla den thymamai ti eixa kanei kai to eikonidio tou virtual grafei 100% apanw
Posted Thu 21 Mar 19 @ 5:45 pm
Με την αναβάθμιση, άλλαξε το Username ή κατι άλλο που να επηρρεάζει την διαδρομή κάποιων τραγουδιών ?
Ποιόν φακελο έχεις επιλεγμένο, όταν ανοίγει το VirtualDJ ?
Posted Thu 21 Mar 19 @ 6:22 pm
den thymamai pion fakelo eixa proepilogh alla den allakse tipota apolytos kai ta virtual folder douleuoune ola kanonika opws ta eixa
ola idia einai username ktlp
Posted Thu 21 Mar 19 @ 6:24 pm
To setting SetTagsAuto το έχεις στο Ναι ?
Posted Thu 21 Mar 19 @ 6:26 pm
Ναι το έχω στο yes
Posted Thu 21 Mar 19 @ 6:30 pm
kai molis paw na kanw recurse ena virtual folder me ellhnika mou crasharei to virtual kai anoigei pali alla grafei renaming dipla gia 2 deuterolepta kai meta crasharei
- basika auto sumbainei otan kanw recurse to kentriko fakelo me titlo ellinika brika prio sub-virtual_folder exei to problima alla den kserw pws mporw na to dior8wsw
- ekana 2-3 clean db kai mou anoikse kanonika kai pathsa deksi klik remove from this virtual folder osa tragoudia 8elane relocate kai twra den crasharei
(gia na mhn spamarw mnm ta mazepsa se 1 post)
Posted Thu 21 Mar 19 @ 7:00 pm
yparxei periptosi na eixe kolhsei to renaming se kapoio missing file ? pou isws apo palia na to eixa sbhsei kai na eixa afhsei etsi to virtual folder ???
synexizw na to antimetopizw to problima me ot recurse se para pola virtual folder
Posted Thu 21 Mar 19 @ 7:05 pm
to renaming apo oti katalaba den feugei pote.... kai to problima einai sta virtual folder.... otan kanw recurse virtual fodler pou exei polla missing files crasharei kai meta den me afhnei na mpw kan sto vdjfolder otan kleisw kai anoiksw pali to programma mpainw se ena ena vdj folder kai me to pou brw fakelo pou exei missing file mesa ksekinaei to renaming kai den feugei pote ma pote, pataw deksi klik remove from this vdj folder kleinw to virtual to anoigw pali kai exei fygei to renaming... mono etsi ginete... kai meta an kanw recurse douleuei kanonika.....
Posted Thu 21 Mar 19 @ 7:51 pm
To "renaming" το βγάζει όταν κάποιο στοιχείο της database (από Playlist , virtual folder κλπ) δεν έχει το σωστό path, δλδ έχει μετονομαστεί, μεταφερθεί σε άλλη διαδρομή κλπ.
Το relocating που προσπαθεί να κάνει, δεν είναι μόνιμο, και δεν ξέρω πόσο "βαθειά" στους φακέλους ψάχνει μέχρι να σταματήσει, και λογικό είναι όταν κάνεις recurse, να αναθέτεις ένα βαρύ φορτίο στο VDJ, δίσκο, επεξεργαστή κλπ.
Βρές ενα σχετικά μικρό virtual folder που σου βγάζει το renaming, άνοιξέ το με κάποιον editor και δες την διαδρομή, και σύγκρινέτη με την σωστή. Αν είσαι τυχερός και όλα τα paths των αρχείων που προσπαθεί να βρει έχουν κάποιο μοτίβο (πχ έχει αλλάξει γράμμα δίσκου, username κλπ), κάνε ένα batch edit στα virtual folders.
Αν τώρα έχεις κάνει renaming κάποια τραγούδια, ή δεν βγάζεις άκρη, τότε θα πρέπει να τα δεις ένα ενα, να ξεφορτωθείς τα missing, και να τα ξανα-προσθέσεις με το σωστό path. Στο μέλλον, για να αποφύγεις τέτοια ταλαιπωρία, φρόντισε ότι μετακινήσεις και μετονομασίες αρχείων, να τις κάνεις μέσα από το VirtualDJ.
BTW, με το "crash" εννοείς οτι κολλάει , δεν ανταποκρίνεται, ή το VirtualDJ κλείνει και ξανανοίγει από μόνο του ?
Posted Fri 22 Mar 19 @ 7:44 am
Έκανα remove apo ta vdj folder όλα τα τραγούδια που είχα σβήσει στο παρελθόν .. crash εννοώ κλείνει το προγραμμα τερματίζει από μόνο του ... σταμάτησε το πρόβλημα τώρα κάνω recurse και σε πραγματικούς φακέλους με 50κ+ τραγούδια και λειτουργεί κανονικά..... δεν κάνω rename τραγούδια ούτε αλλάζω τίτλους... αυτό έγινε γιατί διέγραψα κάποια τραγούδια λογικά ...
Posted Fri 22 Mar 19 @ 2:15 pm
yparxei dynatotita apenergopoihshs tou renaming ??? emena paradeigma 8a me dieukoline auth h diadikasia na ginete xeirokinhta(na yparxei as poume deksi klik auto relocate missing files) h apo to deksi klik relocate wste na apofeugoume tetoia problimatakia se playlist history vdj folder giati an symbei tin wra pou paizoume kai to renaming argisei para poly 8a eimaste me 99% cpu ka8os prospa8ei na brei ta arxeia h 8a mporouse na ginei epilogh sta settings se kapoio epomeno build tou virtual ??
sas euxaristw gia ton xrono sas, tin boitheia sas kai tis apanthseis sto problima pou antimetopisa
Posted Fri 22 Mar 19 @ 5:39 pm
Posted Fri 22 Mar 19 @ 5:41 pm
αυτο το renaming εχει καψει κοσμο...2 μηνες αντιμετωπίζω πρόβλημα (άλλο) κ ακομα λυση δεν εχουμε βρει.φανταζομαι τελικα η λυση θα βγει σε
καποιο update..αν βρεις τροπο να το λυσεις το πρόβλημα πες μου κ εμενα γιατι εχω δοκιμασει τα παντα.εμενα βεβαια μου κανει αλλα:κάθε φορα
που μεταφερω αρχειο μεσα από το virtual βγαζει το renaming το οποιο οση ωρα ειναι εκει δεν με αφηνει να μετακινησω άλλο αρχειο
ουτε κ να σβησω αρχεια..
Posted Sat 23 Mar 19 @ 12:06 pm
