Looking for some advise on the best native VDJ mid-priced 4 channel mixer for Windows Laptop Windows 10. Tried upgrading to a Denon MC6000MK2, but had popping noise and Denon blames VDJ... suggested changing to Serato. Any suggestions? Thank you to anyone that takes the time to respond.
Posted Sun 25 Nov 18 @ 2:00 pm
I would post your settings for the dennon, it should work ok if the settings are correct and the pc is up to scatch
Posted Sun 25 Nov 18 @ 4:24 pm
Serato Dj is now VDJ8...Lol, I remember when Serato user use to brag about their software being better then VDJ but it's funny to see how Serato has been copying VDJ in the last few years. Lol !!
Posted Mon 26 Nov 18 @ 9:35 am
ladydjjean wrote :
Denon blames VDJ...
Why would they do that when they absolutely know that it's not true...
Maybe just a lazy support guy
Anyway... Quite a few people here use the mc6000 mk1 and mk2 without issues, so you should be able to get that up and running without issues
I'm sure someone will be able to help you
Posted Mon 26 Nov 18 @ 11:44 am
Just uninstall the Denon Asio drivers and use WASAPI instead. Problem solved.
Posted Mon 26 Nov 18 @ 12:09 pm
