Echo Indigo DJ Review
http://axledentaldj.com/forum/viewtopic.php?p=612#612
Posted Tue 28 Oct 03 @ 4:08 pm
Maybe I'm blind, but I don't see you mentioning testing VDJ with it. Pretty cool PC Card though, and a a thorough review.
Regards;
Redman247
Regards;
Redman247
Posted Tue 28 Oct 03 @ 5:03 pm
Thanks a mil for the review.
Do I understand correctly that both stereo outs are equivalent hardware-wise? I mean, 1 output can go into one channel of my mixtable, and the other into the other channel?
Or is the second out on the card really just a headphone/monitoring out?
This is relevant since when using a mix table with VDJ, the headphone/monitoring is only done on the mix table, and not in the VDJ software or on the sound card.
Hope you understand ;-)
best,
arie
best,
arie
Posted Sat 01 Nov 03 @ 5:23 pm
Yes the second out on the card is really just a headphone out
in the other is a out for a mixer/amp. Here is a link
http://www.echoaudio.com/Products/IndigoDJ/index.php
What I would like to know does the Hercules Audio - DJ Console need two sound cards?
Posted Sat 01 Nov 03 @ 7:34 pm
hi audio000,
I already know the website you mention, but the review comments did give me reason to ask specifically if it will be possible to connect the 2 outputs of the card to 2 separate channels on my mixer, and monitor them through the headphones connected to the mixer, instead of through the headphone-out on the card itself.
I still am not sure if/how this will work.
Bye,
arie
Bye,
arie
Posted Wed 05 Nov 03 @ 12:29 pm
Ok I think I get what you are asking yes you can I will try this. I can't see why not. Lets say output one (Line out) is on line one of the mixer and output two (headphone out) is on ine two. All you would need to do is remember that line one is still your master for your laptop. This could be a good idea thanks DJ von Smoothousen.
Posted Wed 05 Nov 03 @ 3:45 pm
I would also like to know if it is possible to use both channels of indigo to connect to my mixer as I do with any 3D card. Usually front stereo for channel 1 and rear for channel 2.
Posted Sat 08 Nov 03 @ 12:05 pm
abnorm
Yes you can
Yes you can
Posted Sun 09 Nov 03 @ 7:39 pm
audio000:
Hows the quality on the indigo dj?
Are you happy with it?
Posted Tue 11 Nov 03 @ 12:24 am
Sorry forgat to specify...
SOUND quality I mean???
Posted Tue 11 Nov 03 @ 12:26 am
Yes I like the sound of Echo Indigo DJ card but I am thinking about trying the Hercules Audio DJ Console for that cd like feel
Posted Tue 11 Nov 03 @ 3:29 am
GOTCHA!!
Thanks for the respopnse.
I'm thinking of ordering one this week.
PEACE.
PEACE.
Posted Tue 11 Nov 03 @ 7:26 pm
sorry been away for a while
YES! absolutely 2x2 = 4 real channels
>does it work with virtual DJ
Yes!
Excellent. top notch, clean and pure.
Excellent
Yes, not selling it anytime soon
Yes!
Excellent
Posted Wed 12 Nov 03 @ 3:08 am
THANKS WirelessDJ.
Reading your comments, I feel like go get it right now.
PEACE.
PEACE.
Posted Wed 12 Nov 03 @ 5:00 pm
Just keep this in mind when setting it up
In echo indigo DJ sound control panel under virtual output, you MUST MUTE channels 1-2 or the audio will bleed through -- and you will be confused The Audiotrak Maya 44 does the same thing; I remember being totally confused when I first got it.
Posted Wed 12 Nov 03 @ 6:41 pm
GOT IT!!
Thanks.
Thanks.
Posted Fri 14 Nov 03 @ 12:09 am
I have one more question. If I am going to get this card, I would be using it with an external mixer. I heard that the second output is meant for headphones, and it's amplified.
When connecting both channels to an external mixer, are they going to have different volume levels and possible EQs?
Posted Fri 14 Nov 03 @ 11:30 pm
Yes, I have exactly the same question as the previous poster.
Hope someone can provide the answer!
arie
arie
Posted Wed 26 Nov 03 @ 9:05 am
there are 4 hardware channels.
yes you can connect channel1/2 to line-input1 on some mixer and put channel 3/4 to another line-input.
Posted Wed 13 Oct 04 @ 11:25 am
Just remember, The trial version does not allow for a split 2 channel output.
If you are going to spend the money on an audio device, perhaps it's a good time to also purchase the full version of VirtualDJ.
Posted Wed 13 Oct 04 @ 2:16 pm
