Discussion about Halloween Sound FX
Posted Wed 10 Oct 18 @ 6:07 pm
Brilliant work. Thank you for this
Posted Wed 10 Oct 18 @ 9:52 pm
The installer for Windows (Win8) does not seem to work for me! Mac installer works fine!
Posted Thu 11 Oct 18 @ 12:45 pm
Did you run the installer? Works here..
It basically just extracts a zip to the sampler folder
Posted Thu 11 Oct 18 @ 1:57 pm
I don't believe I downloaded a zip file!
When I click on the downloaded file it asks me what program I would like to use to open it!
Posted Thu 11 Oct 18 @ 4:06 pm
This is what I downloaded. When I click it it does nothing!
install_halloweensoundfx
Posted Thu 11 Oct 18 @ 4:40 pm
Make sure the file name has .exe on the end.
It's that simple!
It's that simple!
Posted Thu 11 Oct 18 @ 4:45 pm
Will try that now!
Posted Thu 11 Oct 18 @ 4:46 pm
THANK YOU SIR! YOU ARE A TRUE GENTLEMAN! IT WORKS PERFECTLY!!!
Posted Thu 11 Oct 18 @ 4:54 pm
Posted Fri 12 Oct 18 @ 1:19 pm
Thanks
Posted Wed 16 Nov 22 @ 2:44 am
