Hello,
I had buy a Akai AMX as a Mixer and an Numark DJ2Go2 Midi controller to use the Wheels together with the AMX Mixer Part.
I work with Mac OSX High Sierra...
the problem is, i can‘t use booth „controller“ Hardware together. I can‘t controll the decks with Numark DJ2Go...
Give it a turnaround solution for this combination? Because with Serato give it no problems ...
Posted Thu 27 Sep 18 @ 9:12 pm
Check VDJ Settings-->Controllers tab, select the DJ2GO2 and see on the right side if its assigned to later decks than 1,2.
Most likely - since both offer mixer capabilities, and both are some kind of all-in one controllers - VDJ automatically assigned DJ2GO2 to Decks 3,4 (or even later ones)
Posted Fri 28 Sep 18 @ 12:51 pm
