I'm trying to use one key to crossfade to either directions. For instance If the crossfader is at deck 1 when i press the assign key the crossfader will move to deck 2 and the same key should move the crossfader back to deck 1.
Auto crossfade does this but if the crossfader should already move from deck 1 even slightly it will go back to deck 1 rather than over to deck 2. Any help will be appreciated. Thanks
Posted Sun 26 Aug 18 @ 4:03 pm
Perhaps something like this ..
param_bigger 50% crossfader ? auto_crossfade 0% : auto_crossfade 100%
Posted Sun 26 Aug 18 @ 4:38 pm
It works. But if the fader is already at 50% it sends crossfader over to deck 2 all the time even if thats where its coming from. Thanks for your helping.
Posted Sun 26 Aug 18 @ 9:39 pm
You can try something like this then:
param_bigger 60% crossfader ? auto_crossfade 0% : param_smaller 40% crossfader ?auto_crossfade 100% : nothing
This will leave a dead area between 40% and 60% where no action will be performed
Of course you can tweak the numbers as you like
Posted Mon 27 Aug 18 @ 8:22 am
i first setup my account and was asked to pick a dj name: ViZionZ ProJect, why is it that after clearing my cashe and coming back it's like i don't exist and have to put in a new account....not cool. ViZionZ ProJect is my moniker and everything is listed by that name on my digital id. please merge these accounts and also i used my product key on that account and it won't allow me to use it on this one. so i am deprived the content that i want from you. please fix this for me so i can continue what i started. if i get no response to this i will start calling you. i am very grateful for any help
Barry
Vizionz Project
Barry
Vizionz Project
Posted Mon 27 Aug 18 @ 10:13 am
Thats the thing tho. Action must be at 50%. I tweaked the numbers but crossfader still goes to one side when fader is @ 50%. How about this, How do i make the crossfader go to whichever deck is active by using the same key?
Posted Mon 27 Aug 18 @ 11:22 am
@2B Visionz,
1. Your issue has nothing to do with this subject, please don't hijack another members thread, thank you.
2. Your issue can't be solved on the forum, please contact support here.
Posted Mon 27 Aug 18 @ 8:14 pm
Can anyone of you script geniuses help me with this por favor?
Posted Sun 02 Sep 18 @ 5:05 am
I sometimes use Control+PageUp and Control+PageDown for the crossfader in some situations. I suppose you need it mapped to a button instead of the kb?
Posted Sun 02 Sep 18 @ 6:10 am
Yes. I found a solution. Deck 1 pfl ? crossfader 0% : crossfader 100%. assign this script to a key. It will send the fader to deck that's active.
Posted Sat 08 Sep 18 @ 6:50 pm
