Hi, I am using the latest version of VDJ8.3 with a ReLoop Touch.
I am using groups of 4 compatible tracks on 4 decks, with up to 4 tracks running simultaneously.
When I am finished using the current group of 4, I will outro with say ideally 2 tracks on decks 3 & 4.
While so doing, I will load the first 2 of the next group on decks 1 & 2. But not always, I may want to outro with decks 1 & 4, while I load 2& 3.
The problem I am facing at this point, is that I use track 1 in deck 1 as the Master, and when I drop the track into the deck it does not always have it's own BPM.
The best I can work out, is it seems to be ok if track 1 is dropped into deck 1 before I drop any of the other new group track in.
If I drop say track 2 into deck 2 first, when I drop track 1 into deck 1 it will have the BPM of track 2, even though deck 1 is set as master.
Then there does not seem to be anything i can do to get track 1 to change to it's own BPM. I have to unload all tracks and start again.
Can someone please help me get this sorted. There must be an easy way to solve this? Hope you understand the above?
Posted Thu 02 Aug 18 @ 9:07 am
I don't have your controller but this sounds like autoBPMMatch to me. Do you have it turned on? Quick write-up here.
If you turn it off then Virtual DJ will not match BPM to the playing deck(s).
Posted Thu 02 Aug 18 @ 11:55 am
Hi Phil, I had a look at that, and found nothing that worked for me.
What I have found though, is if deck 1 is not set as master and I drop the track in there that I want to keep at it's own BPM, it will only become the BPM of which ever track is set as master at the time, which is understandable. But there seems to be no way to have it change the BPM back to it's original after switching deck 1 to master. (Please enlighten me if there is). The only way to do it seems to be switching deck 1 to master before dropping the track in. Which is ok, I just have to remember to do that. I would just like a better understanding of how it works. For now I'll just keep experimenting.
Posted Sun 05 Aug 18 @ 10:09 pm
Check the scratch panel if beatlock is on any of the decks turn then all off
Posted Mon 06 Aug 18 @ 2:34 am
Beat lock is all off.
Posted Mon 06 Aug 18 @ 3:08 am
