why is the song title on the video monitor and how do i get it off???
Posted Thu 28 Jun 18 @ 11:47 pm
got the title off.. now this damn wave form.. why would they do this without a clear way to remove ?
Posted Thu 28 Jun 18 @ 11:51 pm
The first post in this forum might help.
Posted Fri 29 Jun 18 @ 12:00 am
try, right click on the preview window
GK
GK
thank you but none of those options remove it.. maybe im not explaining it right.. on the tvs there is a blue wave form going across the monitors and a spinning record
Posted Fri 29 Jun 18 @ 12:04 am
thank you so much.. fixed it.. please tell them to let me decide what i want to obstruct the karaoke singers from seeing the words on the monitor . thank god i fixed it before I started.
thank you very much for your quick and helpful response..
have a good night
Posted Fri 29 Jun 18 @ 12:09 am
how did you get rid of the song title and the spinning record after the latest update its driving me crazy.
Thanks in advance
Thanks in advance
Posted Fri 29 Jun 18 @ 1:13 am
Posted Fri 29 Jun 18 @ 1:32 am
go into setting click options, then click all settings in the search , then go to video and its use video skin click no... your welcome.. keep rocking...
Posted Fri 29 Jun 18 @ 4:53 am
Glad you read the pop up that would have came up after installing VDJ 2018. The answer to your question would have been in that message.
Posted Fri 29 Jun 18 @ 6:28 am
