My AUTO SYNC option is not working. Before if a song was playing in 105 bpm was synced with 128 bpm, both the songs became either 105 or 128. But now both the songs are remaining the same bpm. Can u guys fix this problem and give me a solution?
Posted Wed 13 Jun 18 @ 9:14 am
You mean when you click sync?
The BPMs are probaby too far apart compared to your range
You change the range on the dot menu under the pitch fader:
Posted Wed 13 Jun 18 @ 10:56 am
Agreed. That's a huge difference in tempo. Most DJs would not even attempt to mix tracks which differ in BPM so much.
Posted Wed 13 Jun 18 @ 6:29 pm
