So i'm a bit intrigued about this Scratch DNA
Where can i find out more info, i see you can automate scratches, i'm hoping you can record 'performed' scratches for later use but not sure how it all works??
Any info appreciated.
Posted Wed 13 Jun 18 @ 5:04 am
Posted Wed 13 Jun 18 @ 5:10 am
scratch DNA "over" function, if you turn off it, you can only hear the scratch sound. but the issue is when the effect end, it takes one beat back. If any possible, make it as slip mode, it will be great.
Posted Tue 10 Jul 18 @ 3:50 pm
Got something working for single press and slip when finished, will work on multipress.
Posted Tue 10 Jul 18 @ 4:01 pm
locodog, Thanks~ but it doesn't work out when I give the comment as ~ slip & effect_active 18 "Scratch DNA" while_pressed
Is there any suggestion for it?
Posted Tue 10 Jul 18 @ 4:23 pm
slip on & effect_active "scratch dna" & repeat_start_instant "slipIsBetter" 33ms & effect_active "scratch dna" ? nothing : slip off & repeat_stop "slipIsBetter"
Thats just one button, I could rejig the default scratch pad page but am unsure if it will be accepted, I suppose I casn but try.
Posted Tue 10 Jul 18 @ 11:43 pm
Thanks!!!! it really works!!!! perfect~~
Posted Thu 12 Jul 18 @ 12:34 pm
The Vu meter jumps in red when the script is used, can you please modify it to reduce the gain when in use and reset gain to original setting?
Posted Fri 13 Jul 18 @ 3:06 pm
