Why do you need to use older versions?
Posted Thu 07 Jun 18 @ 1:52 pm
bigron1 wrote :
For .shader files to play in older versions of vdj we need a suitable plugin. The .dll part of the native shader plugin is incorporated in vdj.exe. That's a bit of a disappointment. I had hoped to try it this weekend.
The compatibility with webGL shaders from shaderToy is a complicated integration, it's not just a simple plugin (even though it's presented as one in the interface to keep things intuitive).
Also, VirtualDJ 2018 was built on top of the VirtualDJ 8 code, it's not a complete rewrite like VirtualDJ 8 was from VirtualDJ 7. It just added new features, so it's perfectly safe and as stable as it was before.
There should be no reason for you not to upgrade to VirtualDJ 2018 once it is officially released.
Posted Thu 07 Jun 18 @ 4:10 pm
Leneer, in your playlist, this one (Colored Steam) is apparently not compatible with Virtual DJ.
https://www.shadertoy.com/view/4sdfDS | view on shadertoy | copy link
This one
https://www.shadertoy.com/view/Mld3Rn | view on shadertoy | copy link is really pin sharp on the Shadertoy site, but pixelated and blocky in VDJ. Anyone know why?
Another with problems in VDJ -
https://www.shadertoy.com/view/Xsdczr | view on shadertoy | copy link runs fine on the site, but in VDJ gives a large black rectangle with the effect only at the edges.
https://www.shadertoy.com/view/4sdfDS | view on shadertoy | copy link This one
https://www.shadertoy.com/view/Mld3Rn | view on shadertoy | copy link is really pin sharp on the Shadertoy site, but pixelated and blocky in VDJ. Anyone know why?Another with problems in VDJ -
Posted Thu 07 Jun 18 @ 7:35 pm
Is anyone else having problems with it crashing your browser / No WebGL enabled in your browser. Shadertoy will load static content only.
It's a nightmare site for crashing
Posted Thu 07 Jun 18 @ 8:01 pm
groovindj wrote :
In your playlist, this one (Colored Steam) is apparently not compatible with Virtual DJ.
This one
https://www.shadertoy.com/view/Xsdczr | view on shadertoy | copy link runs fine on the site, but in VDJ gives a large black rectangle with the effect only at the edges.this one is working fine for me
https://www.shadertoy.com/view/Mld3Rn | view on shadertoy | copy link maybe depends on your video card?
i have had some not work though
Posted Thu 07 Jun 18 @ 8:10 pm
Same PC & card. Shadertoy = sharp. VDJ = blocky.
Posted Thu 07 Jun 18 @ 8:20 pm
The GPU is critical. On a very old Core2Duo 2.4ghz with onboard graphics only 3 of the .shader files run properly. Some crashed while others ran at a low frame rate. Those files which crashed vdj 2018 can be deleted resulting in an old working system. However on an i5 2.8ghz 3rd gen with onboard graphics all ran well.
There is an option to run low, mid, high and also auto video quality. The default setting is auto.
Posted Thu 07 Jun 18 @ 11:03 pm
With some "heavy" Shaders, the size of the Video Output matters. So while the Shader is shown smooth in a small preview in Shadertoy web page, it may not be the same in VirtualDJ when the Video Output is set at Full HD.
Also while you test more Shaders, have the Shadertoy webpage closed in your Internet Browser (or at least have the Shader preview paused), or else your GPU will be doing the job twice
Posted Thu 07 Jun 18 @ 11:14 pm
How do you download shader files from Shadertoy.com?
I can see the code but don't know what to do with it and I cannot see a download button.
It's ok.. I've got it now.
For others: Go to Shadertoy.com and view the effect. Copy the URL of it's webpage. In the VDJ 2018 shader panel/gui enter this URL and click the download button. Easy !
Posted Fri 08 Jun 18 @ 6:40 am
djtouchdan wrote :
Blacksheep doesn't offer the video effects drop down. Largely because this skin was developed prior to it existing.
I may look at updating the skin, but it more likely something NEW might be coming soon!!
In the mean time you can use one of the custom buttons at the top and code it to "video_fx_select" like the screen shop below:
Thank You DJTouchDan. I configured a custom button (had 1 left) as you suggested and it works GREAT!!!. I really like these "Shaders" as they pulse with the beat of the music.
Now moving on to figuring out how to download off their website. There is a request above me that I'm watching for the answer.
Also since you suggested you might be releasing a new BlackSheep Skin, please allow me to suggest a few things.
Change "Loop Select" with the arrows to actual buttons. Loop In and Loop out buttons can be shrunk considerably. Get rid of the 3 HOT CUE buttons as the five on the side are plenty... for more real estate for Loop select buttons. 1/8,1/4,1/2, 3/4,1,2,4,8,16,32
Please more Custom Buttons. Another row above the center top row of 9 for 9 more.
How about a way to reduce the Effects section boxes. You can see from my picture above that the Effects I use take up a lot of room It would be great to be able to change the sizes.
That's about it. I really LOVE your skin. Can't wait for your new release. Thanks from a fan.
Posted Fri 08 Jun 18 @ 6:58 am
So.. besides providing video for simple audio files shaders can also "sex up" normal video tracks if they are overlaid and transparent. Geometry is such an example. We need to work together to find more as it is not clear which are transparent.
There might also be a slight problem with playing two shaders at the same time wasting computer resources. If the option related to playing a shader automatically to acompany a simple audio file is on and also the gui shader button is on then two run simultaneously?
Posted Fri 08 Jun 18 @ 7:33 am
VideoFX > Shader > Config > Download More
Then enter the URL from the shadertoy website.
Posted Fri 08 Jun 18 @ 8:59 am
No, it was the other way around actually.
The effect was sharp & clear on Shadertoy, and I could run it full screen (1920x1080) with no problems.
Put it in VDJ and no matter the size of the video window, the result was similar to YouTube at 240p.
Posted Fri 08 Jun 18 @ 4:59 pm
I like watching funny cat videos on Youtube at 240p :)
Posted Fri 08 Jun 18 @ 5:10 pm
from Shadertoy, copy directly to Shader setup in virtual dj,
Frecuency Visualization
https://www.shadertoy.com/view/MdVSWG | view on shadertoy | copy link Sketch Eyes2
https://www.shadertoy.com/view/4d2cDh | view on shadertoy | copy link Matrix Black and White
https://www.shadertoy.com/view/MlfXzN | view on shadertoy | copy link GK
Posted Fri 08 Jun 18 @ 5:20 pm
I like the first two. Thanks!
Posted Fri 08 Jun 18 @ 5:30 pm
Can you point one from Shadertoy that behaves like this ?
Also, what is your Video card ?
Posted Fri 08 Jun 18 @ 7:19 pm
As mentioned earlier in the thread
It's OK now. I solved it by changing some VDJ settings. It looks sharp now but the frame rate has slowed.
I don't DJ with this PC anyway. I'm downloading shaders from this one and will move them to my laptop later.
https://www.shadertoy.com/view/Mld3Rn | view on shadertoy | copy link It's OK now. I solved it by changing some VDJ settings. It looks sharp now but the frame rate has slowed.
Posted Fri 08 Jun 18 @ 8:38 pm
Hello Guys,
I have some shaders that work in VirtualDJ actually, some are animations some others are cool visualizations... Here the list:
https://www.shadertoy.com/view/4sdBW7 | view on shadertoy | copy link ngWaves11
https://www.shadertoy.com/view/lsdBzX | view on shadertoy | copy link Spiral Of Spirals 2
https://www.shadertoy.com/view/4scfR2 | view on shadertoy | copy link Mobius Trans in hyper 3-space
https://www.shadertoy.com/view/XstfzB | view on shadertoy | copy link Disco Tunnel
https://www.shadertoy.com/view/4dfGzs | view on shadertoy | copy link Voxel Edges
https://www.shadertoy.com/view/lscBRf | view on shadertoy | copy link Rainbow Showoff
https://www.shadertoy.com/view/ldl3W8 | view on shadertoy | copy link Voronoi - distances
https://www.shadertoy.com/view/4sS3zG | view on shadertoy | copy link Dolphin (iq) (need better resolution)
https://www.shadertoy.com/view/XscfzB | view on shadertoy | copy link Zebrazebra
https://www.shadertoy.com/view/4stBzr | view on shadertoy | copy link Light & Motion
https://www.shadertoy.com/view/Xl2XRW | view on shadertoy | copy link Where the river goes
https://www.shadertoy.com/view/4tdSWr | view on shadertoy | copy link 2D Clouds
https://www.shadertoy.com/view/XsdBRj | view on shadertoy | copy link Spiral of Spirals
https://www.shadertoy.com/view/4ttGDH | view on shadertoy | copy link Abstract Glassy Field
https://www.shadertoy.com/view/Xtf3zn | view on shadertoy | copy link Tokyo
https://www.shadertoy.com/view/Mld3Rn | view on shadertoy | copy link Perspex Web Lattice
https://www.shadertoy.com/view/4djGWR | view on shadertoy | copy link Rounded Voxels
https://www.shadertoy.com/view/MlXSWX | view on shadertoy | copy link Abstract Corridor
https://www.shadertoy.com/view/XtdGR7 | view on shadertoy | copy link SH16B WIP: Warp Tunnel (display at low detail)
https://www.shadertoy.com/view/ls3BDH | view on shadertoy | copy link Sound Eclipse RPM
https://www.shadertoy.com/view/XdtfW4 | view on shadertoy | copy link EgaVga.bgi test
https://www.shadertoy.com/view/ltlSWf | view on shadertoy | copy link Flux Core
https://www.shadertoy.com/view/llVXRd | view on shadertoy | copy link Geodesic filling
https://www.shadertoy.com/view/4d3BWH | view on shadertoy | copy link Colorful bubbles
https://www.shadertoy.com/view/4scXzn | view on shadertoy | copy link Winding Merger Tunnel
https://www.shadertoy.com/view/4sGSRV | view on shadertoy | copy link Abstract Plane
https://www.shadertoy.com/view/XsfGRn | view on shadertoy | copy link Heart 2D
https://www.shadertoy.com/view/4slGz4 | view on shadertoy | copy link Demo - Volumetric Lines
https://www.shadertoy.com/view/lssGRM | view on shadertoy | copy link Angels
https://www.shadertoy.com/view/4dBcRD | view on shadertoy | copy link Water waves drag (low detail, still good)
https://www.shadertoy.com/view/lsKyWV | view on shadertoy | copy link curlesque
https://www.shadertoy.com/view/ll2SRy | view on shadertoy | copy link Transparent Cube Field
https://www.shadertoy.com/view/4ds3zn | view on shadertoy | copy link Apollonian
https://www.shadertoy.com/view/MdKyRw | view on shadertoy | copy link Kaleidoscopic iterative function
https://www.shadertoy.com/view/ldGyWW | view on shadertoy | copy link Not A lifestyle choice
https://www.shadertoy.com/view/4sVyDt | view on shadertoy | copy link Menger Helix
https://www.shadertoy.com/view/4s3BR7 | view on shadertoy | copy link No expectations
https://www.shadertoy.com/view/XddBDM | view on shadertoy | copy link Circle Leneer
https://www.shadertoy.com/view/4sGcWz | view on shadertoy | copy link Tropical Fish
https://www.shadertoy.com/view/MdXSzS | view on shadertoy | copy link Galaxy of Universes
https://www.shadertoy.com/view/MdlGzn | view on shadertoy | copy link Torus Jorney
https://www.shadertoy.com/view/lsfGDB | view on shadertoy | copy link Disk - Intersection
https://www.shadertoy.com/view/4ls3zM | view on shadertoy | copy link Manta Ray
https://www.shadertoy.com/view/MsVcRy | view on shadertoy | copy link rm -f
https://www.shadertoy.com/view/ldcfWH | view on shadertoy | copy link simpler audiotunnel (low detail)
https://www.shadertoy.com/view/MtSBDc | view on shadertoy | copy link Golfing Ether
https://www.shadertoy.com/view/Xsyczh | view on shadertoy | copy link One Pass Varanoi
https://www.shadertoy.com/view/lsVyz3 | view on shadertoy | copy link Falling Stars
https://www.shadertoy.com/view/4t2Xzt | view on shadertoy | copy link Subluminic (low detail)
https://www.shadertoy.com/view/MsdBR8 | view on shadertoy | copy link dancing cubes
https://www.shadertoy.com/view/XsKGRW | view on shadertoy | copy link Full Sceene Radial Blur
https://www.shadertoy.com/view/4dVyDd | view on shadertoy | copy link Flower Matrix
https://www.shadertoy.com/view/4dXSzn | view on shadertoy | copy link The cubitree (low detail)
https://www.shadertoy.com/view/XsfGDS | view on shadertoy | copy link IO
https://www.shadertoy.com/view/Xd3SDs | view on shadertoy | copy link Transparent Lattice
https://www.shadertoy.com/view/4s3SRN | view on shadertoy | copy link Fractal Flytrough
https://www.shadertoy.com/view/lsycDG | view on shadertoy | copy link Doodling #7: Speed
https://www.shadertoy.com/view/XdBSzd | view on shadertoy | copy link Tissue (low detail)
https://www.shadertoy.com/view/XsVyDh | view on shadertoy | copy link Bamboo Cave
https://www.shadertoy.com/view/Xs3yDH | view on shadertoy | copy link Fractal Music
https://www.shadertoy.com/view/ldlSzX | view on shadertoy | copy link Synthetic aperture
https://www.shadertoy.com/view/4ljXWh | view on shadertoy | copy link Beneath tge Sea (low detail)
https://www.shadertoy.com/view/MdyyzD | view on shadertoy | copy link gravity field 3d
https://www.shadertoy.com/view/ltyXR1 | view on shadertoy | copy link Re fractal land by kali
https://www.shadertoy.com/view/MdBGDK | view on shadertoy | copy link Rainbow assault (low detail, still good)
https://www.shadertoy.com/view/ltfGDs | view on shadertoy | copy link Fancy ties (Starwars battleships)
https://www.shadertoy.com/view/4stBzH | view on shadertoy | copy link Backing up
https://www.shadertoy.com/view/MdVcRK | view on shadertoy | copy link Polytopes with faces (low detail)
https://www.shadertoy.com/view/MdyyzG | view on shadertoy | copy link Tesla's Laboratory
https://www.shadertoy.com/view/Xdyczz | view on shadertoy | copy link Inverse Interactive (low detail, still good)
https://www.shadertoy.com/view/4l2cD3 | view on shadertoy | copy link Dual 3D Trucget Tiles
https://www.shadertoy.com/view/MlGSzW | view on shadertoy | copy link Re Cypher
https://www.shadertoy.com/view/ldKyWV | view on shadertoy | copy link Visualizer #1
https://www.shadertoy.com/view/4ljfWW | view on shadertoy | copy link On Stage (black Screen)
https://www.shadertoy.com/view/4dyyR1 | view on shadertoy | copy link Elliptical Arc distance
https://www.shadertoy.com/view/lds3zr | view on shadertoy | copy link Rainbows
https://www.shadertoy.com/view/Msd3DN | view on shadertoy | copy link Christmas Delivery
https://www.shadertoy.com/view/Md3yWN | view on shadertoy | copy link Rotozoom Fractal
https://www.shadertoy.com/view/XdSGzR | view on shadertoy | copy link Fiery spiral
https://www.shadertoy.com/view/lsdBD8 | view on shadertoy | copy link Logo Experiment
https://www.shadertoy.com/view/XtBXDz | view on shadertoy | copy link Atmosphere system Test
https://www.shadertoy.com/view/lsX3WH | view on shadertoy | copy link A lot of spheres
https://www.shadertoy.com/view/MlfcR2 | view on shadertoy | copy link Lighthouse (low detail)
https://www.shadertoy.com/view/MdVSDhVoxel | view on shadertoy | copy link Corridor (low detail)
https://www.shadertoy.com/view/Xls3z2 | view on shadertoy | copy link Another Kailset Mod
https://www.shadertoy.com/view/XlcSDr | view on shadertoy | copy link Clickable starfield (low detail)
https://www.shadertoy.com/view/4s2Xzc | view on shadertoy | copy link Cave (low detail)
https://www.shadertoy.com/view/MstXWS | view on shadertoy | copy link Raymarched reaction-diffusion
https://www.shadertoy.com/view/llB3W1 | view on shadertoy | copy link Fractal audio 01
https://www.shadertoy.com/view/ldyyRm | view on shadertoy | copy link KIFS1D
https://www.shadertoy.com/view/4sdyz4 | view on shadertoy | copy link Formation from p7120A
https://www.shadertoy.com/view/4d3fzN | view on shadertoy | copy link Candy Tunnel (low detail, not licensed)
https://www.shadertoy.com/view/ldcyR4 | view on shadertoy | copy link rainbow flow 2
https://www.shadertoy.com/view/4lSXzh | view on shadertoy | copy link Traced Minkowski Tube
https://www.shadertoy.com/view/MddyWX | view on shadertoy | copy link Confetti canon (not licensed)
https://www.shadertoy.com/view/ldGyWz | view on shadertoy | copy link S F I K
https://www.shadertoy.com/view/XsVyDw | view on shadertoy | copy link colors and symmetry
https://www.shadertoy.com/view/ldGczw | view on shadertoy | copy link Abstract Noise
https://www.shadertoy.com/view/ldVyDD | view on shadertoy | copy link Newton thing
https://www.shadertoy.com/view/lslXRS | view on shadertoy | copy link Noise Animation - Lava
https://www.shadertoy.com/view/ltjXWd | view on shadertoy | copy link simple hexagon raymarch
https://www.shadertoy.com/view/lsdcD7 | view on shadertoy | copy link Hexpo
https://www.shadertoy.com/view/lssGW7 | view on shadertoy | copy link Brighton Beach (low detail)
https://www.shadertoy.com/view/MtsSRf | view on shadertoy | copy link Siggraph'15 Workshop (low detail)
https://www.shadertoy.com/view/4lfcRl | view on shadertoy | copy link Cubic truchet Pattern
https://www.shadertoy.com/view/Xd2Bzw | view on shadertoy | copy link Fractal Thing #2
https://www.shadertoy.com/view/XlfXR4 | view on shadertoy | copy link Curvature - Parametric 3D
https://www.shadertoy.com/view/MlSSR1 | view on shadertoy | copy link Metaeux - Sunset (low detail)
https://www.shadertoy.com/view/XsyyDD | view on shadertoy | copy link rainbow noise 2
https://www.shadertoy.com/view/Xd2BWm | view on shadertoy | copy link Abstract Ballon Flight (low resolution)
https://www.shadertoy.com/view/Xsl3zn | view on shadertoy | copy link Warping - texture (low detail, still good)
https://www.shadertoy.com/view/4s2yW1 | view on shadertoy | copy link Bokeh Paralax
https://www.shadertoy.com/view/XdcyW8 | view on shadertoy | copy link I Love you all (simple hearts draw)
https://www.shadertoy.com/view/XljBW3 | view on shadertoy | copy link The cat is a glitch (Matrix)
https://www.shadertoy.com/view/XscyRs | view on shadertoy | copy link bouncy boi on the run (low detail)
https://www.shadertoy.com/view/lt2fDz | view on shadertoy | copy link Torus_thing_8 (not licensed)
https://www.shadertoy.com/view/4dKyRD | view on shadertoy | copy link VArigon's Theorem, Projectively (simple lines)
https://www.shadertoy.com/view/4dSXDd | view on shadertoy | copy link Symetric Origins
https://www.shadertoy.com/view/lslfRN | view on shadertoy | copy link Dry Rocky Gorge
https://www.shadertoy.com/view/MsjGRt | view on shadertoy | copy link Invader's
https://www.shadertoy.com/view/XdfXzn | view on shadertoy | copy link Sample pinning (low detail)
https://www.shadertoy.com/view/ld3Szs | view on shadertoy | copy link 3D Cellular Tiling
https://www.shadertoy.com/view/XstfDr | view on shadertoy | copy link djmusicball
https://www.shadertoy.com/view/4s2Sz3 | view on shadertoy | copy link train ride (low detail)
https://www.shadertoy.com/view/4ttGWM | view on shadertoy | copy link 301's fire shader - Remix 3
https://www.shadertoy.com/view/4djXzz | view on shadertoy | copy link Topologica
https://www.shadertoy.com/view/XdVcRW | view on shadertoy | copy link p6mm kaleidoscope (low detail)
https://www.shadertoy.com/view/4ddcRN | view on shadertoy | copy link Cubic Honeycombs
https://www.shadertoy.com/view/ldccWj | view on shadertoy | copy link Mobius transformations (simple)
https://www.shadertoy.com/view/Mscyz2 | view on shadertoy | copy link Sea at Night (low detail)
https://www.shadertoy.com/view/llGGzh | view on shadertoy | copy link Maze Lattice
https://www.shadertoy.com/view/XlXXWj | view on shadertoy | copy link Subterranean Fly-though (low detail)
https://www.shadertoy.com/view/MddcWf | view on shadertoy | copy link Every line is straight (simple)
https://www.shadertoy.com/view/Xljcz1 | view on shadertoy | copy link BloOoOoOoOom
https://www.shadertoy.com/view/Msl3WH | view on shadertoy | copy link Warp Speed
https://www.shadertoy.com/view/4ddyDn | view on shadertoy | copy link Water Ripples (low detail, 1/4 displayed)
https://www.shadertoy.com/view/XtBfz1 | view on shadertoy | copy link 100000 Pins Valley
https://www.shadertoy.com/view/Ms3fW8 | view on shadertoy | copy link Modular Times table (simple change color figure)
https://www.shadertoy.com/view/lsSGRc | view on shadertoy | copy link Blocks
https://www.shadertoy.com/view/ltBczc | view on shadertoy | copy link Ocean structure
https://www.shadertoy.com/view/ltjSRD | view on shadertoy | copy link Ray marched Mesh Terrain (low detail)
https://www.shadertoy.com/view/MtdSWS | view on shadertoy | copy link Industrial complex
https://www.shadertoy.com/view/ltSczW | view on shadertoy | copy link Random isometric Blocks (simple)
https://www.shadertoy.com/view/Xsdczl | view on shadertoy | copy link Twisted Ladder 2 (simple)
https://www.shadertoy.com/view/XtlGDH | view on shadertoy | copy link kalizyl
https://www.shadertoy.com/view/XsyGRW | view on shadertoy | copy link 2D SDF Toy
https://www.shadertoy.com/view/4dSBRm | view on shadertoy | copy link Jagged Landscape
https://www.shadertoy.com/view/XtsBRS | view on shadertoy | copy link Mobius Weave
https://www.shadertoy.com/view/MtsBW8 | view on shadertoy | copy link Buoyant Balls
https://www.shadertoy.com/view/4dccR4 | view on shadertoy | copy link Prism
https://www.shadertoy.com/view/lstyWH | view on shadertoy | copy link Perpetual Motion Machines
https://www.shadertoy.com/view/ll2BzR | view on shadertoy | copy link Tempting Mariner
https://www.shadertoy.com/view/XlfyWl | view on shadertoy | copy link oOoOoOoOoOoOoOoOoOoOoOoOoOoO
https://www.shadertoy.com/view/ldSBD3 | view on shadertoy | copy link Infinite Yin Yangs 2
https://www.shadertoy.com/view/Md23Wz | view on shadertoy | copy link Mars Jetpack (low detail)
https://www.shadertoy.com/view/4sBGD1 | view on shadertoy | copy link Fast Balls
https://www.shadertoy.com/view/Xl2BDy | view on shadertoy | copy link Grid based PArticules (simple)
https://www.shadertoy.com/view/4tSXRm | view on shadertoy | copy link Jagged Plain
https://www.shadertoy.com/view/MdcyRs | view on shadertoy | copy link PreAlpha Vector Field v.0.0.7
https://www.shadertoy.com/view/4sf3zS | view on shadertoy | copy link Texture twistery (low detail)
https://www.shadertoy.com/view/Xddfz8 | view on shadertoy | copy link FuzzyBrainC (not licensed)
https://www.shadertoy.com/view/4tySDW | view on shadertoy | copy link Blueprint of the Architekt
https://www.shadertoy.com/view/Msy3RD | view on shadertoy | copy link SmoothLife gliders (black & white)
https://www.shadertoy.com/view/MtKSRc | view on shadertoy | copy link Low Frequency Flow
https://www.shadertoy.com/view/MlfczH | view on shadertoy | copy link Optical desconstruction 1b (low detail)
https://www.shadertoy.com/view/llffDM | view on shadertoy | copy link Banding Gradients (black & White)
https://www.shadertoy.com/view/4tlBWH | view on shadertoy | copy link Morning city & aurora & bloom
https://www.shadertoy.com/view/lljfW1 | view on shadertoy | copy link Seascape Clubber VJ version
https://www.shadertoy.com/view/4ljGD1 | view on shadertoy | copy link Waves Remix (low detail half effect)
https://www.shadertoy.com/view/MdSGRc | view on shadertoy | copy link Varonoi Metrics by Iq (low detail)
https://www.shadertoy.com/view/4dBSRK | view on shadertoy | copy link Color Grid (low detail)
https://www.shadertoy.com/view/XdsGWs | view on shadertoy | copy link Star PSF (low detail)
https://www.shadertoy.com/view/ldjyzc | view on shadertoy | copy link Mountain Path (low detail)
https://www.shadertoy.com/view/4scGWj | view on shadertoy | copy link Electro (simple)
https://www.shadertoy.com/view/4lX3RB | view on shadertoy | copy link kali-traps d
https://www.shadertoy.com/view/Mdcczr | view on shadertoy | copy link pasql riff 2 (pink moving effect)
https://www.shadertoy.com/view/4tXcDl | view on shadertoy | copy link Quadratic toolkit (low detail)
https://www.shadertoy.com/view/MdycRD | view on shadertoy | copy link Spiral in one equation
https://www.shadertoy.com/view/XtjcW3 | view on shadertoy | copy link Starfield dots II
https://www.shadertoy.com/view/ltc3R7 | view on shadertoy | copy link Gas Explosion
https://www.shadertoy.com/view/MdSBRc | view on shadertoy | copy link Surface Mesh Generation (low detail)
https://www.shadertoy.com/view/Msl3Rn | view on shadertoy | copy link Chains and Gears
https://www.shadertoy.com/view/Ml2fDh | view on shadertoy | copy link abstract by leon (not licensed. black & white)
https://www.shadertoy.com/view/llSyzz | view on shadertoy | copy link The Ride never ends (low detail)
https://www.shadertoy.com/view/ltBcRc | view on shadertoy | copy link More colerful than average
https://www.shadertoy.com/view/XsSfW1 | view on shadertoy | copy link Rainbow twister
https://www.shadertoy.com/view/4sycRD | view on shadertoy | copy link Johndp blinker (strobe effect)
https://www.shadertoy.com/view/XlXcW4 | view on shadertoy | copy link Integer Hash II (noise screen effect)
https://www.shadertoy.com/view/MdXBzn | view on shadertoy | copy link The big path
https://www.shadertoy.com/view/4slGRM | view on shadertoy | copy link Water (low detail)
https://www.shadertoy.com/view/ltsGz4 | view on shadertoy | copy link Llamels (low detail)
https://www.shadertoy.com/view/MldSz8 | view on shadertoy | copy link Voronoi Fractal
https://www.shadertoy.com/view/4s3yDH | view on shadertoy | copy link Just Some Moving Colors (simple)
https://www.shadertoy.com/view/MlSBWG | view on shadertoy | copy link Opera Island}
https://www.shadertoy.com/view/MtSXRm | view on shadertoy | copy link Luminiscent Tiles
https://www.shadertoy.com/view/lllBWn | view on shadertoy | copy link Positive Energy In Wroclaw
https://www.shadertoy.com/view/XlSBz1 | view on shadertoy | copy link Polar snowflakes (simple)
https://www.shadertoy.com/view/XsSGWm | view on shadertoy | copy link Dragon's Gullet
https://www.shadertoy.com/view/4lBfRD | view on shadertoy | copy link Square tunnel (191 chars) (simple B&W)
https://www.shadertoy.com/view/4tSBDz | view on shadertoy | copy link Another Grid of Spheres (low detail)
https://www.shadertoy.com/view/ld23DV | view on shadertoy | copy link Box intersection (low detail)
https://www.shadertoy.com/view/XlBBDR | view on shadertoy | copy link SDF isolines of metaball-cluster (low detail)
https://www.shadertoy.com/view/llG3zy | view on shadertoy | copy link Faster Voronoi Edge Distance ( detail 3/4 effect)
https://www.shadertoy.com/view/MtBBWw | view on shadertoy | copy link Meduses (some jellyfish) (low detail)
https://www.shadertoy.com/view/4tB3zV | view on shadertoy | copy link Promethean (not licensed, low detail)
https://www.shadertoy.com/view/MssXDn | view on shadertoy | copy link Camera obsession #1 (low detail, simple)
https://www.shadertoy.com/view/4dl3R4 | view on shadertoy | copy link Snowy
https://www.shadertoy.com/view/Xl2SRR | view on shadertoy | copy link firework Show (low detail simple)
https://www.shadertoy.com/view/lstyWB | view on shadertoy | copy link pulse 2a
https://www.shadertoy.com/view/lljBzz | view on shadertoy | copy link Dizzy The Egg!
https://www.shadertoy.com/view/MlG3zh | view on shadertoy | copy link Canyon Pass (low detail)
https://www.shadertoy.com/view/MtBcR3 | view on shadertoy | copy link Iq Apollonian Fork
https://www.shadertoy.com/view/XtjfDy | view on shadertoy | copy link Polar 3b (225 chars) Rainbow colors
https://www.shadertoy.com/view/4lscDn | view on shadertoy | copy link Construction set
https://www.shadertoy.com/view/Xst3WX | view on shadertoy | copy link Everyday011-Rush
https://www.shadertoy.com/view/4tKXzV | view on shadertoy | copy link Industrial Tunnel
https://www.shadertoy.com/view/lsSfz1 | view on shadertoy | copy link Round Voronoi Borders 2
https://www.shadertoy.com/view/MsfGzr | view on shadertoy | copy link To the road of ribbon (low detail)
https://www.shadertoy.com/view/MsScRD | view on shadertoy | copy link Abstract tunnel with water (low detail)
https://www.shadertoy.com/view/ltB3Dw | view on shadertoy | copy link Psychofract
https://www.shadertoy.com/view/Ms3yRH | view on shadertoy | copy link distance X angle (simple svp type)
https://www.shadertoy.com/view/4tXSDf | view on shadertoy | copy link Varonoi water
https://www.shadertoy.com/view/XljBRh | view on shadertoy | copy link feathers field / overlap tiling (rainbow colors)
https://www.shadertoy.com/view/Xtlyzl | view on shadertoy | copy link Apollonian Elevator-247 chars
https://www.shadertoy.com/view/XllBDl | view on shadertoy | copy link Festive Pentagram
https://www.shadertoy.com/view/4tXyDH | view on shadertoy | copy link dynamic Epsilon Moebius
https://www.shadertoy.com/view/4dl3W8 | view on shadertoy | copy link Phoning Home
https://www.shadertoy.com/view/4tscR8 | view on shadertoy | copy link Optical deconstruction 5b
https://www.shadertoy.com/view/lt2BDD | view on shadertoy | copy link swirling color orbs
https://www.shadertoy.com/view/4dsBz4 | view on shadertoy | copy link Hex Voxel Scene
https://www.shadertoy.com/view/lsdcWN | view on shadertoy | copy link Interactive caustic (not licensed simple)
https://www.shadertoy.com/view/4lyGDV | view on shadertoy | copy link Voronoi Column Tracing (low detail)
https://www.shadertoy.com/view/MtjfR3 | view on shadertoy | copy link machine not learning
https://www.shadertoy.com/view/XtlfDs | view on shadertoy | copy link Merry Xmas 2017
https://www.shadertoy.com/view/4djBDR | view on shadertoy | copy link Particules 4
https://www.shadertoy.com/view/MlB3Wt | view on shadertoy | copy link hypertexture - trabeculum 2 (low detail)
https://www.shadertoy.com/view/4dt3zn | view on shadertoy | copy link Raymarched Reflections
https://www.shadertoy.com/view/MdyGzR | view on shadertoy | copy link Lights In Smoke
https://www.shadertoy.com/view/MsySWK | view on shadertoy | copy link Raymarched 2d sierpinski
https://www.shadertoy.com/view/MtXczn | view on shadertoy | copy link Hal4000 (simple)
https://www.shadertoy.com/view/XsKXRh | view on shadertoy | copy link Cellular Lattice
https://www.shadertoy.com/view/XtfBz4 | view on shadertoy | copy link Lightweight Lighthouse
https://www.shadertoy.com/view/lllcW4 | view on shadertoy | copy link Voxel City at sunset
https://www.shadertoy.com/view/lt3SzH | view on shadertoy | copy link Rounded Voronoi Blocks
https://www.shadertoy.com/view/ll2Bzd | view on shadertoy | copy link Polar 4 (211 chars) (rainbow colors)
https://www.shadertoy.com/view/lt3XD8 | view on shadertoy | copy link Twisted Geometry
https://www.shadertoy.com/view/4lfBWB | view on shadertoy | copy link Backlit Lighthouse (low detail)
https://www.shadertoy.com/view/ldycW3 | view on shadertoy | copy link Blue box (simple)
https://www.shadertoy.com/view/XlXcRj | view on shadertoy | copy link Wilhem Kali Röntgen
https://www.shadertoy.com/view/4ty3WW | view on shadertoy | copy link Another IFS
https://www.shadertoy.com/view/Xd2BWz | view on shadertoy | copy link 2tweet fluid totally
https://www.shadertoy.com/view/MtByRh | view on shadertoy | copy link Lensing
https://www.shadertoy.com/view/ltlfRn | view on shadertoy | copy link First Fractal Attempt (Black & White)
https://www.shadertoy.com/view/MsX3D2 | view on shadertoy | copy link Loxodrome (low detail)
https://www.shadertoy.com/view/Xt2BDG | view on shadertoy | copy link Trippy Waves (spiral)
https://www.shadertoy.com/view/4sdXDX | view on shadertoy | copy link Smooth Voronoi Contours (low detail) (phsycodelic)
https://www.shadertoy.com/view/XsKXzc | view on shadertoy | copy link KIFS Flythrough (low detail)
https://www.shadertoy.com/view/MtSBR1 | view on shadertoy | copy link Lighthouse with Ship
https://www.shadertoy.com/view/XdlSDH | view on shadertoy | copy link Dueling Mandelbulbs
https://www.shadertoy.com/view/XlXGWf | view on shadertoy | copy link EiffeBox
https://www.shadertoy.com/view/XlS3DD | view on shadertoy | copy link Spectrum Analyzer (In stripes, take other in the background)
https://www.shadertoy.com/view/Mlj3WV | view on shadertoy | copy link 2D Led Spectrum - Visualiser
https://www.shadertoy.com/view/lsdczr | view on shadertoy | copy link Cloud tunnel attempt
https://www.shadertoy.com/view/XlXSzf | view on shadertoy | copy link Explotion No.12 (low detail)
https://www.shadertoy.com/view/lslyRn | view on shadertoy | copy link Star Nest VR
https://www.shadertoy.com/view/MtfGWM | view on shadertoy | copy link Holy Grail Quest II
https://www.shadertoy.com/view/4llXD7 | view on shadertoy | copy link Rounded Box - distance 2D (geometric)
https://www.shadertoy.com/view/Xlf3z4 | view on shadertoy | copy link Congrats Luxo Jr (low detail) (Pixar lamp)
https://www.shadertoy.com/view/XtsXRX | view on shadertoy | copy link Crazy Waves
https://www.shadertoy.com/view/lljfWc | view on shadertoy | copy link 29/2018
https://www.shadertoy.com/view/4sdBW7 | view on shadertoy | copy link ngWaves11+
https://www.shadertoy.com/view/lsdBzX | view on shadertoy | copy link Spiral Of Spirals 2+
https://www.shadertoy.com/view/4scfR2 | view on shadertoy | copy link Mobius Trans in hyper 3-space+
https://www.shadertoy.com/view/XstfzB | view on shadertoy | copy link Disco Tunnel+
https://www.shadertoy.com/view/4dfGzs | view on shadertoy | copy link Voxel Edges+
https://www.shadertoy.com/view/lscBRf | view on shadertoy | copy link Rainbow Showoff+
https://www.shadertoy.com/view/ldl3W8 | view on shadertoy | copy link Voronoi - distances+
https://www.shadertoy.com/view/4sS3zG | view on shadertoy | copy link Dolphin (iq) (need better resolution)+
https://www.shadertoy.com/view/XscfzB | view on shadertoy | copy link Zebrazebra+
https://www.shadertoy.com/view/4stBzr | view on shadertoy | copy link Light & Motion+
https://www.shadertoy.com/view/Xl2XRW | view on shadertoy | copy link Where the river goes+
https://www.shadertoy.com/view/4tdSWr | view on shadertoy | copy link 2D Clouds+
https://www.shadertoy.com/view/XsdBRj | view on shadertoy | copy link Spiral of Spirals+
https://www.shadertoy.com/view/4ttGDH | view on shadertoy | copy link Abstract Glassy Field+
https://www.shadertoy.com/view/Xtf3zn | view on shadertoy | copy link Tokyo+
https://www.shadertoy.com/view/Mld3Rn | view on shadertoy | copy link Perspex Web Lattice+
https://www.shadertoy.com/view/4djGWR | view on shadertoy | copy link Rounded Voxels+
https://www.shadertoy.com/view/MlXSWX | view on shadertoy | copy link Abstract Corridor+
https://www.shadertoy.com/view/XtdGR7 | view on shadertoy | copy link SH16B WIP: Warp Tunnel (display at low detail)+
https://www.shadertoy.com/view/ls3BDH | view on shadertoy | copy link Sound Eclipse RPM+
https://www.shadertoy.com/view/XdtfW4 | view on shadertoy | copy link EgaVga.bgi test+
https://www.shadertoy.com/view/ltlSWf | view on shadertoy | copy link Flux Core+
https://www.shadertoy.com/view/llVXRd | view on shadertoy | copy link Geodesic filling+
https://www.shadertoy.com/view/4d3BWH | view on shadertoy | copy link Colorful bubbles+
https://www.shadertoy.com/view/4scXzn | view on shadertoy | copy link Winding Merger Tunnel+
https://www.shadertoy.com/view/4sGSRV | view on shadertoy | copy link Abstract Plane+
https://www.shadertoy.com/view/XsfGRn | view on shadertoy | copy link Heart 2D+
https://www.shadertoy.com/view/4slGz4 | view on shadertoy | copy link Demo - Volumetric Lines+
https://www.shadertoy.com/view/lssGRM | view on shadertoy | copy link Angels+
https://www.shadertoy.com/view/4dBcRD | view on shadertoy | copy link Water waves drag (low detail, still good)+
https://www.shadertoy.com/view/lsKyWV | view on shadertoy | copy link curlesque+
https://www.shadertoy.com/view/ll2SRy | view on shadertoy | copy link Transparent Cube Field+
https://www.shadertoy.com/view/4ds3zn | view on shadertoy | copy link Apollonian+
https://www.shadertoy.com/view/MdKyRw | view on shadertoy | copy link Kaleidoscopic iterative function+
https://www.shadertoy.com/view/ldGyWW | view on shadertoy | copy link Not A lifestyle choice+
https://www.shadertoy.com/view/4sVyDt | view on shadertoy | copy link Menger Helix+
https://www.shadertoy.com/view/4s3BR7 | view on shadertoy | copy link No expectations+
https://www.shadertoy.com/view/XddBDM | view on shadertoy | copy link Circle Leneer+
https://www.shadertoy.com/view/4sGcWz | view on shadertoy | copy link Tropical Fish+
https://www.shadertoy.com/view/MdXSzS | view on shadertoy | copy link Galaxy of Universes+
https://www.shadertoy.com/view/MdlGzn | view on shadertoy | copy link Torus Jorney+
https://www.shadertoy.com/view/lsfGDB | view on shadertoy | copy link Disk - Intersection+
https://www.shadertoy.com/view/4ls3zM | view on shadertoy | copy link Manta Ray+
https://www.shadertoy.com/view/MsVcRy | view on shadertoy | copy link rm -f+
https://www.shadertoy.com/view/ldcfWH | view on shadertoy | copy link simpler audiotunnel (low detail)+
https://www.shadertoy.com/view/MtSBDc | view on shadertoy | copy link Golfing Ether+
https://www.shadertoy.com/view/Xsyczh | view on shadertoy | copy link One Pass Varanoi+
https://www.shadertoy.com/view/lsVyz3 | view on shadertoy | copy link Falling Stars+
https://www.shadertoy.com/view/4t2Xzt | view on shadertoy | copy link Subluminic (low detail)+
https://www.shadertoy.com/view/MsdBR8 | view on shadertoy | copy link dancing cubes+
https://www.shadertoy.com/view/XsKGRW | view on shadertoy | copy link Full Sceene Radial Blur+
https://www.shadertoy.com/view/4dVyDd | view on shadertoy | copy link Flower Matrix+
https://www.shadertoy.com/view/4dXSzn | view on shadertoy | copy link The cubitree (low detail)+
https://www.shadertoy.com/view/XsfGDS | view on shadertoy | copy link IO+
https://www.shadertoy.com/view/Xd3SDs | view on shadertoy | copy link Transparent Lattice+
https://www.shadertoy.com/view/4s3SRN | view on shadertoy | copy link Fractal Flytrough+
https://www.shadertoy.com/view/lsycDG | view on shadertoy | copy link Doodling #7: Speed+
https://www.shadertoy.com/view/XdBSzd | view on shadertoy | copy link Tissue (low detail)+
https://www.shadertoy.com/view/XsVyDh | view on shadertoy | copy link Bamboo Cave+
https://www.shadertoy.com/view/Xs3yDH | view on shadertoy | copy link Fractal Music+
https://www.shadertoy.com/view/ldlSzX | view on shadertoy | copy link Synthetic aperture+
https://www.shadertoy.com/view/4ljXWh | view on shadertoy | copy link Beneath tge Sea (low detail)+
https://www.shadertoy.com/view/MdyyzD | view on shadertoy | copy link gravity field 3d+
https://www.shadertoy.com/view/ltyXR1 | view on shadertoy | copy link Re fractal land by kali+
https://www.shadertoy.com/view/MdBGDK | view on shadertoy | copy link Rainbow assault (low detail, still good)+
https://www.shadertoy.com/view/ltfGDs | view on shadertoy | copy link Fancy ties (Starwars battleships)+
https://www.shadertoy.com/view/4stBzH | view on shadertoy | copy link Backing up+
https://www.shadertoy.com/view/MdVcRK | view on shadertoy | copy link Polytopes with faces (low detail)+
https://www.shadertoy.com/view/MdyyzG | view on shadertoy | copy link Tesla's Laboratory+
https://www.shadertoy.com/view/Xdyczz | view on shadertoy | copy link Inverse Interactive (low detail, still good)+
https://www.shadertoy.com/view/4l2cD3 | view on shadertoy | copy link Dual 3D Trucget Tiles+
https://www.shadertoy.com/view/MlGSzW | view on shadertoy | copy link Re Cypher+
https://www.shadertoy.com/view/ldKyWV | view on shadertoy | copy link Visualizer #1-
https://www.shadertoy.com/view/4ljfWW | view on shadertoy | copy link On Stage (black Screen)+
https://www.shadertoy.com/view/4dyyR1 | view on shadertoy | copy link Elliptical Arc distance+
https://www.shadertoy.com/view/lds3zr | view on shadertoy | copy link Rainbows+
https://www.shadertoy.com/view/Msd3DN | view on shadertoy | copy link Christmas Delivery+
https://www.shadertoy.com/view/Md3yWN | view on shadertoy | copy link Rotozoom Fractal+
https://www.shadertoy.com/view/XdSGzR | view on shadertoy | copy link Fiery spiral+
https://www.shadertoy.com/view/lsdBD8 | view on shadertoy | copy link Logo Experiment+
https://www.shadertoy.com/view/XtBXDz | view on shadertoy | copy link Atmosphere system Test+
https://www.shadertoy.com/view/lsX3WH | view on shadertoy | copy link A lot of spheres+
https://www.shadertoy.com/view/MlfcR2 | view on shadertoy | copy link Lighthouse (low detail)+
https://www.shadertoy.com/view/MdVSDhVoxel | view on shadertoy | copy link Corridor (low detail)+
https://www.shadertoy.com/view/Xls3z2 | view on shadertoy | copy link Another Kailset Mod+
https://www.shadertoy.com/view/XlcSDr | view on shadertoy | copy link Clickable starfield (low detail)+
https://www.shadertoy.com/view/4s2Xzc | view on shadertoy | copy link Cave (low detail)+
https://www.shadertoy.com/view/MstXWS | view on shadertoy | copy link Raymarched reaction-diffusion+
https://www.shadertoy.com/view/llB3W1 | view on shadertoy | copy link Fractal audio 01+
https://www.shadertoy.com/view/ldyyRm | view on shadertoy | copy link KIFS1D+
https://www.shadertoy.com/view/4sdyz4 | view on shadertoy | copy link Formation from p7120A+
https://www.shadertoy.com/view/4d3fzN | view on shadertoy | copy link Candy Tunnel (low detail, not licensed)+
https://www.shadertoy.com/view/ldcyR4 | view on shadertoy | copy link rainbow flow 2+
https://www.shadertoy.com/view/4lSXzh | view on shadertoy | copy link Traced Minkowski Tube+
https://www.shadertoy.com/view/MddyWX | view on shadertoy | copy link Confetti canon (not licensed)+
https://www.shadertoy.com/view/ldGyWz | view on shadertoy | copy link S F I K+
https://www.shadertoy.com/view/XsVyDw | view on shadertoy | copy link colors and symmetry+
https://www.shadertoy.com/view/ldGczw | view on shadertoy | copy link Abstract Noise+
https://www.shadertoy.com/view/ldVyDD | view on shadertoy | copy link Newton thing+
https://www.shadertoy.com/view/lslXRS | view on shadertoy | copy link Noise Animation - Lava+
https://www.shadertoy.com/view/ltjXWd | view on shadertoy | copy link simple hexagon raymarch+
https://www.shadertoy.com/view/lsdcD7 | view on shadertoy | copy link Hexpo+
https://www.shadertoy.com/view/lssGW7 | view on shadertoy | copy link Brighton Beach (low detail)+
https://www.shadertoy.com/view/MtsSRf | view on shadertoy | copy link Siggraph'15 Workshop (low detail)+
https://www.shadertoy.com/view/4lfcRl | view on shadertoy | copy link Cubic truchet Pattern+
https://www.shadertoy.com/view/Xd2Bzw | view on shadertoy | copy link Fractal Thing #2+
https://www.shadertoy.com/view/XlfXR4 | view on shadertoy | copy link Curvature - Parametric 3D+
https://www.shadertoy.com/view/MlSSR1 | view on shadertoy | copy link Metaeux - Sunset (low detail)+
https://www.shadertoy.com/view/XsyyDD | view on shadertoy | copy link rainbow noise 2+
https://www.shadertoy.com/view/Xd2BWm | view on shadertoy | copy link Abstract Ballon Flight (low resolution)+
https://www.shadertoy.com/view/Xsl3zn | view on shadertoy | copy link Warping - texture (low detail, still good)+
https://www.shadertoy.com/view/4s2yW1 | view on shadertoy | copy link Bokeh Paralax+
https://www.shadertoy.com/view/XdcyW8 | view on shadertoy | copy link I Love you all (simple hearts draw)+
https://www.shadertoy.com/view/XljBW3 | view on shadertoy | copy link The cat is a glitch (Matrix)+
https://www.shadertoy.com/view/XscyRs | view on shadertoy | copy link bouncy boi on the run (low detail)+
https://www.shadertoy.com/view/lt2fDz | view on shadertoy | copy link Torus_thing_8 (not licensed)+
https://www.shadertoy.com/view/4dKyRD | view on shadertoy | copy link VArigon's Theorem, Projectively (simple lines)+
https://www.shadertoy.com/view/4dSXDd | view on shadertoy | copy link Symetric Origins+
https://www.shadertoy.com/view/lslfRN | view on shadertoy | copy link Dry Rocky Gorge+
https://www.shadertoy.com/view/MsjGRt | view on shadertoy | copy link Invader's+
https://www.shadertoy.com/view/XdfXzn | view on shadertoy | copy link Sample pinning (low detail)+
https://www.shadertoy.com/view/ld3Szs | view on shadertoy | copy link 3D Cellular Tiling+
https://www.shadertoy.com/view/XstfDr | view on shadertoy | copy link djmusicball+
https://www.shadertoy.com/view/4s2Sz3 | view on shadertoy | copy link train ride (low detail)+
https://www.shadertoy.com/view/4ttGWM | view on shadertoy | copy link 301's fire shader - Remix 3+
https://www.shadertoy.com/view/4djXzz | view on shadertoy | copy link Topologica+
https://www.shadertoy.com/view/XdVcRW | view on shadertoy | copy link p6mm kaleidoscope (low detail)+
https://www.shadertoy.com/view/4ddcRN | view on shadertoy | copy link Cubic Honeycombs+
https://www.shadertoy.com/view/ldccWj | view on shadertoy | copy link Mobius transformations (simple)+
https://www.shadertoy.com/view/Mscyz2 | view on shadertoy | copy link Sea at Night (low detail)+
https://www.shadertoy.com/view/llGGzh | view on shadertoy | copy link Maze Lattice+
https://www.shadertoy.com/view/XlXXWj | view on shadertoy | copy link Subterranean Fly-though (low detail)+
https://www.shadertoy.com/view/MddcWf | view on shadertoy | copy link Every line is straight (simple)+
https://www.shadertoy.com/view/Xljcz1 | view on shadertoy | copy link BloOoOoOoOom+
https://www.shadertoy.com/view/Msl3WH | view on shadertoy | copy link Warp Speed+
https://www.shadertoy.com/view/4ddyDn | view on shadertoy | copy link Water Ripples (low detail, 1/4 displayed)+
https://www.shadertoy.com/view/XtBfz1 | view on shadertoy | copy link 100000 Pins Valley+
https://www.shadertoy.com/view/Ms3fW8 | view on shadertoy | copy link Modular Times table (simple change color figure)+
https://www.shadertoy.com/view/lsSGRc | view on shadertoy | copy link Blocks+
https://www.shadertoy.com/view/ltBczc | view on shadertoy | copy link Ocean structure+
https://www.shadertoy.com/view/ltjSRD | view on shadertoy | copy link Ray marched Mesh Terrain (low detail)+
https://www.shadertoy.com/view/MtdSWS | view on shadertoy | copy link Industrial complex+
https://www.shadertoy.com/view/ltSczW | view on shadertoy | copy link Random isometric Blocks (simple)+
https://www.shadertoy.com/view/Xsdczl | view on shadertoy | copy link Twisted Ladder 2 (simple)+
https://www.shadertoy.com/view/XtlGDH | view on shadertoy | copy link kalizyl+
https://www.shadertoy.com/view/XsyGRW | view on shadertoy | copy link 2D SDF Toy+
https://www.shadertoy.com/view/4dSBRm | view on shadertoy | copy link Jagged Landscape+
https://www.shadertoy.com/view/XtsBRS | view on shadertoy | copy link Mobius Weave+
https://www.shadertoy.com/view/MtsBW8 | view on shadertoy | copy link Buoyant Balls+
https://www.shadertoy.com/view/4dccR4 | view on shadertoy | copy link Prism+
https://www.shadertoy.com/view/lstyWH | view on shadertoy | copy link Perpetual Motion Machines+
https://www.shadertoy.com/view/ll2BzR | view on shadertoy | copy link Tempting Mariner+
https://www.shadertoy.com/view/XlfyWl | view on shadertoy | copy link oOoOoOoOoOoOoOoOoOoOoOoOoOoO+
https://www.shadertoy.com/view/ldSBD3 | view on shadertoy | copy link Infinite Yin Yangs 2+
https://www.shadertoy.com/view/Md23Wz | view on shadertoy | copy link Mars Jetpack (low detail)+
https://www.shadertoy.com/view/4sBGD1 | view on shadertoy | copy link Fast Balls+
https://www.shadertoy.com/view/Xl2BDy | view on shadertoy | copy link Grid based PArticules (simple)+
https://www.shadertoy.com/view/4tSXRm | view on shadertoy | copy link Jagged Plain+
https://www.shadertoy.com/view/MdcyRs | view on shadertoy | copy link PreAlpha Vector Field v.0.0.7+
https://www.shadertoy.com/view/4sf3zS | view on shadertoy | copy link Texture twistery (low detail)+
https://www.shadertoy.com/view/Xddfz8 | view on shadertoy | copy link FuzzyBrainC (not licensed)+
https://www.shadertoy.com/view/4tySDW | view on shadertoy | copy link Blueprint of the Architekt+
https://www.shadertoy.com/view/Msy3RD | view on shadertoy | copy link SmoothLife gliders (black & white)+
https://www.shadertoy.com/view/MtKSRc | view on shadertoy | copy link Low Frequency Flow+
https://www.shadertoy.com/view/MlfczH | view on shadertoy | copy link Optical desconstruction 1b (low detail)+
https://www.shadertoy.com/view/llffDM | view on shadertoy | copy link Banding Gradients (black & White)+
https://www.shadertoy.com/view/4tlBWH | view on shadertoy | copy link Morning city & aurora & bloom+
https://www.shadertoy.com/view/lljfW1 | view on shadertoy | copy link Seascape Clubber VJ version+
https://www.shadertoy.com/view/4ljGD1 | view on shadertoy | copy link Waves Remix (low detail half effect)+
https://www.shadertoy.com/view/MdSGRc | view on shadertoy | copy link Varonoi Metrics by Iq (low detail)+
https://www.shadertoy.com/view/4dBSRK | view on shadertoy | copy link Color Grid (low detail)+
https://www.shadertoy.com/view/XdsGWs | view on shadertoy | copy link Star PSF (low detail)+
https://www.shadertoy.com/view/ldjyzc | view on shadertoy | copy link Mountain Path (low detail)+
https://www.shadertoy.com/view/4scGWj | view on shadertoy | copy link Electro (simple)+
https://www.shadertoy.com/view/4lX3RB | view on shadertoy | copy link kali-traps d+
https://www.shadertoy.com/view/Mdcczr | view on shadertoy | copy link pasql riff 2 (pink moving effect)+
https://www.shadertoy.com/view/4tXcDl | view on shadertoy | copy link Quadratic toolkit (low detail)+
https://www.shadertoy.com/view/MdycRD | view on shadertoy | copy link Spiral in one equation+
https://www.shadertoy.com/view/XtjcW3 | view on shadertoy | copy link Starfield dots II+
https://www.shadertoy.com/view/ltc3R7 | view on shadertoy | copy link Gas Explosion+
https://www.shadertoy.com/view/MdSBRc | view on shadertoy | copy link Surface Mesh Generation (low detail)+
https://www.shadertoy.com/view/Msl3Rn | view on shadertoy | copy link Chains and Gears+
https://www.shadertoy.com/view/Ml2fDh | view on shadertoy | copy link abstract by leon (not licensed. black & white)+
https://www.shadertoy.com/view/llSyzz | view on shadertoy | copy link The Ride never ends (low detail)+
https://www.shadertoy.com/view/ltBcRc | view on shadertoy | copy link More colerful than average+
https://www.shadertoy.com/view/XsSfW1 | view on shadertoy | copy link Rainbow twister+
https://www.shadertoy.com/view/4sycRD | view on shadertoy | copy link Johndp blinker (strobe effect)+
https://www.shadertoy.com/view/XlXcW4 | view on shadertoy | copy link Integer Hash II (noise screen effect)+
https://www.shadertoy.com/view/MdXBzn | view on shadertoy | copy link The big path+
https://www.shadertoy.com/view/4slGRM | view on shadertoy | copy link Water (low detail)+
https://www.shadertoy.com/view/ltsGz4 | view on shadertoy | copy link Llamels (low detail)+
https://www.shadertoy.com/view/MldSz8 | view on shadertoy | copy link Voronoi Fractal+
https://www.shadertoy.com/view/4s3yDH | view on shadertoy | copy link Just Some Moving Colors (simple)+
https://www.shadertoy.com/view/MlSBWG | view on shadertoy | copy link Opera Island}+
https://www.shadertoy.com/view/MtSXRm | view on shadertoy | copy link Luminiscent Tiles+
https://www.shadertoy.com/view/lllBWn | view on shadertoy | copy link Positive Energy In Wroclaw+
https://www.shadertoy.com/view/XlSBz1 | view on shadertoy | copy link Polar snowflakes (simple)+
https://www.shadertoy.com/view/XsSGWm | view on shadertoy | copy link Dragon's Gullet+
https://www.shadertoy.com/view/4lBfRD | view on shadertoy | copy link Square tunnel (191 chars) (simple B&W)+
https://www.shadertoy.com/view/4tSBDz | view on shadertoy | copy link Another Grid of Spheres (low detail)+
https://www.shadertoy.com/view/ld23DV | view on shadertoy | copy link Box intersection (low detail)+
https://www.shadertoy.com/view/XlBBDR | view on shadertoy | copy link SDF isolines of metaball-cluster (low detail)+
https://www.shadertoy.com/view/llG3zy | view on shadertoy | copy link Faster Voronoi Edge Distance ( detail 3/4 effect)+
https://www.shadertoy.com/view/MtBBWw | view on shadertoy | copy link Meduses (some jellyfish) (low detail)+
https://www.shadertoy.com/view/4tB3zV | view on shadertoy | copy link Promethean (not licensed, low detail)+
https://www.shadertoy.com/view/MssXDn | view on shadertoy | copy link Camera obsession #1 (low detail, simple)+
https://www.shadertoy.com/view/4dl3R4 | view on shadertoy | copy link Snowy+
https://www.shadertoy.com/view/Xl2SRR | view on shadertoy | copy link firework Show (low detail simple)+
https://www.shadertoy.com/view/lstyWB | view on shadertoy | copy link pulse 2a+
https://www.shadertoy.com/view/lljBzz | view on shadertoy | copy link Dizzy The Egg!+
https://www.shadertoy.com/view/MlG3zh | view on shadertoy | copy link Canyon Pass (low detail)+
https://www.shadertoy.com/view/MtBcR3 | view on shadertoy | copy link Iq Apollonian Fork+
https://www.shadertoy.com/view/XtjfDy | view on shadertoy | copy link Polar 3b (225 chars) Rainbow colors+
https://www.shadertoy.com/view/4lscDn | view on shadertoy | copy link Construction set+
https://www.shadertoy.com/view/Xst3WX | view on shadertoy | copy link Everyday011-Rush+
https://www.shadertoy.com/view/4tKXzV | view on shadertoy | copy link Industrial Tunnel+
https://www.shadertoy.com/view/lsSfz1 | view on shadertoy | copy link Round Voronoi Borders 2+
https://www.shadertoy.com/view/MsfGzr | view on shadertoy | copy link To the road of ribbon (low detail)+
https://www.shadertoy.com/view/MsScRD | view on shadertoy | copy link Abstract tunnel with water (low detail)+
https://www.shadertoy.com/view/ltB3Dw | view on shadertoy | copy link Psychofract+
https://www.shadertoy.com/view/Ms3yRH | view on shadertoy | copy link distance X angle (simple svp type)+
https://www.shadertoy.com/view/4tXSDf | view on shadertoy | copy link Varonoi water+
https://www.shadertoy.com/view/XljBRh | view on shadertoy | copy link feathers field / overlap tiling (rainbow colors)+
https://www.shadertoy.com/view/Xtlyzl | view on shadertoy | copy link Apollonian Elevator-247 chars+
https://www.shadertoy.com/view/XllBDl | view on shadertoy | copy link Festive Pentagram+
https://www.shadertoy.com/view/4tXyDH | view on shadertoy | copy link dynamic Epsilon Moebius+
https://www.shadertoy.com/view/4dl3W8 | view on shadertoy | copy link Phoning Home+
https://www.shadertoy.com/view/4tscR8 | view on shadertoy | copy link Optical deconstruction 5b+
https://www.shadertoy.com/view/lt2BDD | view on shadertoy | copy link swirling color orbs+
https://www.shadertoy.com/view/4dsBz4 | view on shadertoy | copy link Hex Voxel Scene+
https://www.shadertoy.com/view/lsdcWN | view on shadertoy | copy link Interactive caustic (not licensed simple)+
https://www.shadertoy.com/view/4lyGDV | view on shadertoy | copy link Voronoi Column Tracing (low detail)+
https://www.shadertoy.com/view/MtjfR3 | view on shadertoy | copy link machine not learning+
https://www.shadertoy.com/view/XtlfDs | view on shadertoy | copy link Merry Xmas 2017+
https://www.shadertoy.com/view/4djBDR | view on shadertoy | copy link Particules 4+
https://www.shadertoy.com/view/MlB3Wt | view on shadertoy | copy link hypertexture - trabeculum 2 (low detail)+
https://www.shadertoy.com/view/4dt3zn | view on shadertoy | copy link Raymarched Reflections+
https://www.shadertoy.com/view/MdyGzR | view on shadertoy | copy link Lights In Smoke+
https://www.shadertoy.com/view/MsySWK | view on shadertoy | copy link Raymarched 2d sierpinski+
https://www.shadertoy.com/view/MtXczn | view on shadertoy | copy link Hal4000 (simple)+
https://www.shadertoy.com/view/XsKXRh | view on shadertoy | copy link Cellular Lattice+
https://www.shadertoy.com/view/XtfBz4 | view on shadertoy | copy link Lightweight Lighthouse+
https://www.shadertoy.com/view/lllcW4 | view on shadertoy | copy link Voxel City at sunset+
https://www.shadertoy.com/view/lt3SzH | view on shadertoy | copy link Rounded Voronoi Blocks+
https://www.shadertoy.com/view/ll2Bzd | view on shadertoy | copy link Polar 4 (211 chars) (rainbow colors)+
https://www.shadertoy.com/view/lt3XD8 | view on shadertoy | copy link Twisted Geometry+
https://www.shadertoy.com/view/4lfBWB | view on shadertoy | copy link Backlit Lighthouse (low detail)+
https://www.shadertoy.com/view/ldycW3 | view on shadertoy | copy link Blue box (simple)+
https://www.shadertoy.com/view/XlXcRj | view on shadertoy | copy link Wilhem Kali Röntgen+
https://www.shadertoy.com/view/4ty3WW | view on shadertoy | copy link Another IFS+
https://www.shadertoy.com/view/Xd2BWz | view on shadertoy | copy link 2tweet fluid totally+
https://www.shadertoy.com/view/MtByRh | view on shadertoy | copy link Lensing+
https://www.shadertoy.com/view/ltlfRn | view on shadertoy | copy link First Fractal Attempt (Black & White)+
https://www.shadertoy.com/view/MsX3D2 | view on shadertoy | copy link Loxodrome (low detail)+
https://www.shadertoy.com/view/Xt2BDG | view on shadertoy | copy link Trippy Waves (spiral)+
https://www.shadertoy.com/view/4sdXDX | view on shadertoy | copy link Smooth Voronoi Contours (low detail) (phsycodelic)+
https://www.shadertoy.com/view/XsKXzc | view on shadertoy | copy link KIFS Flythrough (low detail)+
https://www.shadertoy.com/view/MtSBR1 | view on shadertoy | copy link Lighthouse with Ship+
https://www.shadertoy.com/view/XdlSDH | view on shadertoy | copy link Dueling Mandelbulbs+
https://www.shadertoy.com/view/XlXGWf | view on shadertoy | copy link EiffeBox+
https://www.shadertoy.com/view/XlS3DD | view on shadertoy | copy link Spectrum Analyzer (In stripes, take other in the background)+
https://www.shadertoy.com/view/Mlj3WV | view on shadertoy | copy link 2D Led Spectrum - Visualiser+
https://www.shadertoy.com/view/lsdczr | view on shadertoy | copy link Cloud tunnel attempt+
https://www.shadertoy.com/view/XlXSzf | view on shadertoy | copy link Explotion No.12 (low detail)+
https://www.shadertoy.com/view/lslyRn | view on shadertoy | copy link Star Nest VR+
https://www.shadertoy.com/view/MtfGWM | view on shadertoy | copy link Holy Grail Quest II+
https://www.shadertoy.com/view/4llXD7 | view on shadertoy | copy link Rounded Box - distance 2D (geometric)+
https://www.shadertoy.com/view/Xlf3z4 | view on shadertoy | copy link Congrats Luxo Jr (low detail) (Pixar lamp)+
https://www.shadertoy.com/view/XtsXRX | view on shadertoy | copy link Crazy Waves+
https://www.shadertoy.com/view/lljfWc | view on shadertoy | copy link 29/2018Posted Fri 08 Jun 18 @ 9:00 pm
ACW, a lot of those are very slow frame rate, or not really suited to DJ work.
Here's some I found:
https://www.shadertoy.com/view/MsBSzW | view on shadertoy | copy link DanceWalker1
https://www.shadertoy.com/view/4dyfW1 | view on shadertoy | copy link m4-mid-0-m4x
https://www.shadertoy.com/view/XstBDj | view on shadertoy | copy link pixelated
https://www.shadertoy.com/view/XssGRj | view on shadertoy | copy link Audio Reaktive
https://www.shadertoy.com/view/Msf3Dn | view on shadertoy | copy link Sound Flower
https://www.shadertoy.com/view/Msf3Dn | view on shadertoy | copy link Sound FlowerPosted Sat 09 Jun 18 @ 7:50 am
