other ones not working fine https://www.shadertoy.com/view/llSGDh | view on shadertoy | copy link https://www.shadertoy.com/view/4lj3W1 | view on shadertoy | copy link
Posted Sat 03 Apr 21 @ 11:50 pm
Oh there are so many that either don't work in VDJ as they're supposed to, or result in the "not compatible" message. I've given up listing them here as I'm not aware of it ever resulting in any action.
Posted Sun 04 Apr 21 @ 9:04 am
This one downloads and compiles but doesn't display anything at all in VDJ 64 bit on PC.
https://www.shadertoy.com/view/tdfyRl | view on shadertoy | copy link
@devs Can you give us some feedback as to why? Maybe take a look and get it working?
Posted Sat 10 Apr 21 @ 10:26 pm
Maybe one day the Atomix devs will look at why some of these shaders don't work properly in VDJ and fix things...
https://www.shadertoy.com/view/fd2GD1 | view on shadertoy | copy link
Doesn't show any colours in VDJ at all.
Posted Sat 01 May 21 @ 3:59 pm
But when the Shader makers make these,are they even thinking of us?..(sight ).. :(
Posted Sat 01 May 21 @ 10:33 pm
was making a video with vdj and shaders..deleted some from the huge pack mentioned before,went looking fpr more,many not compatible,here is one new...https://www.shadertoy.com/view/flfGW8
Posted Fri 28 May 21 @ 10:07 pm
and another..https://www.shadertoy.com/view/3sySRK
Posted Fri 28 May 21 @ 10:11 pm
and another...https://www.shadertoy.com/view/7tlGWN
Posted Fri 28 May 21 @ 10:14 pm
Nice one!...
https://www.shadertoy.com/view/tlGfzd | view on shadertoy | copy link
Posted Fri 28 May 21 @ 10:19 pm
another "Tunnel" type..good colors...
https://www.shadertoy.com/view/tlVBWz | view on shadertoy | copy link
Posted Fri 28 May 21 @ 11:13 pm
thanks for editing my post..too much in my hands..here is ET phone home... https://www.shadertoy.com/view/4dl3W8 | view on shadertoy | copy link
Posted Fri 28 May 21 @ 11:29 pm
From time to time i check the shadertoy community looking for new exciting ones, but these are quite boring, uninspired or little worked and the most part of them variations of already seen patterns.
Is it me or the shader hype is dead (at least related to VDJ)?
Posted Sat 17 Jun 23 @ 11:50 pm
i check for new shaders every few weeks. so far i'm up to 1300+ in my library and Klaus and i collaborate on making packs for users to download that pretty much work for most systems - even the underpowered ones - so that there's a decent variety.
granted the shaders arent' specifically being made for us and as far as i know they don't have anyone on staff to make company specific ones... HINT HINT.....
Posted Sun 18 Jun 23 @ 7:59 am
Yeah I added a couple of new ones after seeing this thread had been awoken.
IMO once you've got a large number of them installed, you have enough visual variation going on, so adding more becomes less important. Just over 500 here.
Posted Sun 18 Jun 23 @ 8:45 am
Can you PM a link to these? Iām all for using as many as I can get š
Posted Tue 20 Jun 23 @ 3:55 pm
no need to private message. they're for everyone to use or not as they see fit. Klaus and i collaborated on this one and the previous and now have Ed Carey's helping on the Mac side of it as well.
and they're kinda pre-sorted but of course you can change to your hearts desire
Lots of Shaders
https://www.youtube.com/watch?v=oFZq3oV9Wiw&t=26s
Lots of Shaders
Posted Tue 20 Jun 23 @ 11:37 pm
Yeah I have all of those already lol!
But other then that and going to the shader site I havent found any other list..
Posted Wed 21 Jun 23 @ 2:03 pm
Believe it! (Lol)...I download everyday,but do so on my prefered 32 bit..so a lot on the site wont install...one small trick i do is screengrab the ones that wont install on my 32 bit ( i do have another Alienware 17 running w10,64bit,but its not a 18 inch screen..so screengrab them and make video clips to use on the vdj sampler...one thing instead of just thumbnails ...i wish it would show the actual name on that gui shader selector...would help in sorting out when one becomes a pain...
Posted Thu 22 Jun 23 @ 10:21 pm
