Topic: Script School - Page: 41.85
mg_1978PRO InfinityMember since 2008
hi, where is in setting? And this refresh is for Denon Dj Prime 4 (for example) when file .xml (skin) change and doesn’t need to close the software and restart it to see the changes in the skin?
Thanks
Posted Wed 13 Dec 23 @ 4:11 pm
not a script, it's how the interface & mapping windows have changed visually
Posted Wed 13 Dec 23 @ 4:17 pm
Hi at all, i have problem with script:
sampler_output “headphones”
if i would listen samples only in headphones….i don’t listen any sample :( i have mapped a button: sampler_pfl
but i listen sample only in headphones only when i pushed continuosly the button mapped sampler_pfl.
What is wrong?
thanks
Posted Sat 16 Dec 23 @ 11:26 pm
Trying to figure out how to have my gain go up 4 DBs when ever I hit my "Vocal" button and then switch back to match the other track when I hit the same button again.
This is my "Vocal" button now
var 'stem_page' 1 ? var 'pad_fx_sngl' 1 ? padfx_single 'echo out' 80% 1bt 'stemfx:vocal' smart_pressed : padfx 'echo out' 80% 1bt 'stemfx:vocal' smart_pressed : var 'stem_page' 0 ? stem_pad 'acapella' smart_pressed : stem_pad 'vocal' smart_pressed
Could I get some help please??
Posted Sun 17 Dec 23 @ 3:19 pm
I'm not sure oh how to raise a specific number of dB, I'd just give gain a poke up of a few % and down by the same %
( var vocalBoost 0 ? gain +0.04 & set vocalBoost 1 : gain -0.04 & set vocalBoost 0 ) & var 'stem_page' 1 ? var 'pad_fx_sngl' 1 ? padfx_single 'echo out' 80% 1bt 'stemfx:vocal' smart_pressed : padfx 'echo out' 80% 1bt 'stemfx:vocal' smart_pressed : var 'stem_page' 0 ? stem_pad 'acapella' smart_pressed : stem_pad 'vocal' smart_pressed
Posted Sun 17 Dec 23 @ 3:56 pm
Ok so your script raises the gain but does not turn and keep on the vocal when pressed.
Its close 👍🏾
EDIT
After a restart its working, just need a little more gain now.
Posted Sun 17 Dec 23 @ 4:19 pm
It's your script, I just added a bit for gain on the start in brackets so your script should work as it did.
Posted Sun 17 Dec 23 @ 4:21 pm
Ok I figured out how you boosted it but now when I turn the vocals off I went the gain to match the opposite track on the other deck??
Appreciate the help
Ok so I got it to match the gain but now my button isn't lighting up when the vocal is on. That's the last problem I got 😅
Posted Sun 17 Dec 23 @ 4:24 pm
script for the LED currently?
Posted Sun 17 Dec 23 @ 5:44 pm
It’s on a pad page and I don’t see anything.
It’s just action, pressure action and color.
Posted Sun 17 Dec 23 @ 11:03 pm
What work for me when using vocal sstem to bring up the sound is using loudmax when soloing the vocal. Loco helped me with that script also.
Posted Sun 17 Dec 23 @ 11:38 pm
NOTE:
maybe to check the logic now of the combination script, for the button...
since one now has the gain toggling on/off ...
while the you are using smart_pressed.. which can either have a toggle, or a temporary action..
so there could be unexpected results at times...
check if all works as you wish.
Posted Mon 18 Dec 23 @ 4:15 am
The script up above works just fine, no need to use a plugin. Thanks tho..
Posted Mon 18 Dec 23 @ 2:34 pm
Hi everybody,
Question: Is there a script verb, that kann add, remove, or toggle hashtags on the browsed song. I mean the tags you can add for User 1 and User 2 field.
For me a toggle would be important. Like it can be done in the info bar done by click on the hashtag.
But as a script. Maybe something like
browsed_song_hashtag '#GG' which will add tag '#GG' if not present or will remove the tag, if it was present before.
I wish nice holidays to the team and everybody else!
Cheers Jochen
Posted Fri 22 Dec 23 @ 11:06 am
agadj2PRO InfinityMember since 2021
Good to all,
I am analyzing many songs with multiple bpm
the program creates a poi called BEAT ANCHOR .
I have tried to add an action poi at that point with the following script.
"beatlock on & wait 500ms & beatlock off"
With this I get him to keep the mix paired
But I would like to know if it could be automated so that when making the beatanchor this action is included, either in the Poi itself or creating a new one of action.
Thank you
Posted Wed 27 Dec 23 @ 12:52 pm
İs it possible to down the volume slowly for one of the stems. İ'm using rane four. For exanple i want to down the volume of the melody. What do i have to do
Posted Thu 28 Dec 23 @ 4:30 pm
@ongunbuke check the first post of this thread, there's a topic on repeating scripts [rsi], you'll be manipulating
stem melody
@agadj2
not possible; a beatanchor can't hold an action, probably best to use a APOI at the start of grid unevenness and one at the end.
@EGR
It's on a tag, so you can check the tag and add to the tag with
param_contains 'HASHTAG' `get_browsed_song 'TAG'` ?
if false you can add with
browsed_song 'TAG' 'HASHTAG'
If true, removing part of a tag is not possible with script, but I do have a windows plugin that can do this.
Posted Thu 28 Dec 23 @ 6:03 pm
hi! is there a script in “hotcues” pad that assign an hotcue color yellow if pad is holding 1 second or color “get_deck_color ‘absolute’ “ if pad is pressed without holding?
Thanks a lot
Posted Sat 30 Dec 23 @ 10:34 pm
I thought you'd have been capable of that yourself.
hot_cue 1 & holding ? cue_color 1 "yellow" : get_deck_color 'absolute' & param_cast text & cue_color 1
that works for setting, but fails when you call, which I guess you got to then got stuck.
so this issue is, the order things happening; holding - either reply case does the cue exist ? exists call the cue, not exist create the cue and colour it.
holding ? has_cue 1 ? hot_cue 1 : hot_cue 1 & cue_color 1 "yellow" : has_cue 1 ? hot_cue 1 : hot_cue 1 & get_deck_color 'absolute' & param_cast text & cue_color 1
Posted Sun 31 Dec 23 @ 12:08 am
your script is perfect 👌 thanks!
Posted Mon 01 Jan 24 @ 7:30 pm
89%
