Well another EA release dropped and I'm behind on reporting the additions so I guess I'll work backwards, some points might get their own topic in future
BUILD 7716 (2023-10-16)
-"effect_disable_all mic", "effect_disable_all aux" and "effect_disable_all sampler" scripts added
-"scratchbank_load" without parameters opens a menu to select the bank
-scratchbank_load accepts absolute index or name as parameter as well
-loop_move allows moving loop up to 30 seconds before start or after end of song
Pretty straight forward there, loop_move has been a long time in waiting, scratchbank_load stuff is because of me recently deep diving into scratchbanks [3 years late, 2020 was a blur] and the devs thought my suggestions weren't terrible.
I never discussed effect_disable_all, [and I use it all the time] neither did I get in the single fx slots for mic, sampler, aux, [not often I use them, I just set and forget on the sampler.] I'll maybe ad something somewhere, but they do what it says on the tin.
moving on
Stuff from a little earlier.
set_deck vdjscript to execute script on deck based on another script. The use case for this will have me prattling on for ages. It's a easy script you'd use for complicated scenarios, A quick easy case would be doing stuff across several decks, it's able to pick a deck to be the script default.
I'll do a post on this one, because if you start getting complicated it's useful.
get_automix_song supports column names "artist_before_feat", "feat_after_artist", "title_before_remix" and "remix_after_title"
something mainly for video skin making, automix list has same formatting options the loaded song does.
Also for the skin makers
-sampler_drop, sampler_loop and sampler_mic available as sysicon for skins.
defaultIcons page updated. i1 - 3 if you're interested.
Add 'Full Path' database field for use in scripts.
it's not a real database field, it's a mashup between get_loaded_song "drive" & get_loaded_song "file path". To actually get a real navigable path you had to mash the two together, then still add in a check for online sources.
Now there's "full path" so the old way still works but the new way is cleaner.
-Filter folders can use `` to include script as values to compare to
script in filters, worth it's own topic, you can now get some value from a track and use it in a filter.
I think I'll demo a circle of 5ths filter.
I think that's everything.
moving on
Posted Mon 16 Oct 23 @ 5:40 am
Hi at all: is there a script like virtualfolder_add ‘my_folder’? Because this script add a track focused only if folder ‘my_folder’ is a playlist or sampler_bank….if my_folder is a normal folder in my pc? I could add a track with script?
Thanks a lot
Thanks a lot
Posted Mon 23 Oct 23 @ 10:21 am
Nope, you can't move files around with script, you can place references like how playlists and virtual folders work, but you can't move actual file locations with script.
You could with a plugin.
Posted Mon 23 Oct 23 @ 10:30 am
Thanks everyone for your help so far. I've mapped shift and EQ to to change EQ frequency for low mid high. Using ez remix on the pro skin. However when I adjust it, it didn't show the EQ panel I'm adjusting it. What script do I need to add to momentarily show the EQ panel whilst adjusting it, and then to revert back to the EZremix EQ panel?
Posted Fri 27 Oct 23 @ 9:01 am
YOUR THING & setting eqMode "Frequency" ? : set_var $myEQMode `setting eqMode` & setting eqMode "Frequency" & repeat_start eqRevert 1000ms 1 & get_var $myEQMode & param_cast & setting eqMode
Posted Fri 27 Oct 23 @ 1:51 pm
"Hello, beloved DJ software users! Can you tell me how to make the pad blink in different colors? The function is assigned to pad №1: var “$shift” ? effect_stems ‘kick’ : effect_stems ‘vocal’. With pad №1, I turn on FX:Kick+Vocal and I need the pad to light up alternately in red and blue when this double FX stem is turned on. If I turn on only FX:Vocal, then the pad lights up blue, if I turn on FX:Kick, then the pad lights up red, if FX:Kick+Vocal, then the pad should blink alternately blue and red, when FX: is off, then the LED is gray.
I wrote such a script, but with errors: effect_stems ‘kick’ ? blink 600ms ? color ‘red’ & effect_stems ‘vocal’ ? blink 600ms ? color ‘blue’ : effect_stems_color
Please correct my script.
Posted Sun 29 Oct 23 @ 10:02 pm
One possible solution for the color, could be:
where the last color is to your choosing. gray or black (off) or .. for the pad color when its NOT Kick or Vocal.
Not tested.
PS
I prefer when creating a blinking pad.. to also change the intensity also during the blink, so maybe the blink part of the script becomes:
blink 600ms ? color 'darkred' : color 'blue'
if one's LEDs allow for that.
effect_stems 'kick' ? effect_stems 'vocal' ? blink 600ms ? color 'red' : color 'blue' : color 'red' : effect_stems 'vocal' ? color 'blue' : color 'gray'
Not tested.
PS
Posted Mon 30 Oct 23 @ 2:32 am
I don't know what browser ElementDJ is using but the stylised ‘ “ are not compatible within the script engine.
@IIDEEJAYII I fixed the code block in your reply
Posted Mon 30 Oct 23 @ 5:16 am
Thanks Locodog.. great catch :)
I copied and pasted from OP script.. (not tested)
(and now don't see the stylized single quote in the OP)
Posted Mon 30 Oct 23 @ 6:34 am
@Locodog
Could you elaborate on this as it sounds like it could be interesting:
Posted Mon 30 Oct 23 @ 11:34 am
@DJPhallus when I feel upto it, I've had a few interactions recently, one really positive and several others that treat me like I'm gpt.
The difference left me feeling pretty sour.
unrelated a bit of housekeeping - remembered an old short post I didn't link in the index; Appending a tag
Posted Fri 03 Nov 23 @ 6:24 pm
Quick fire examples, want to use script as a value, just wrap the script in ` `
Artist contains `deck master get_artist` FIND MORE BY CURRENT ARTIST
Bpm > `deck master get_bpm & param_multiply 0.48` and Bpm < `deck master get_bpm & param_multiply 0.52` ~0.5* BPM MATCH
key is `deck master get_key` EXACT KEY MATCH
key is `deck master get_harmonic` EXACT KEY MATCH [vdj figures out key from harmonic]
All very straight forward, lets do something interesting
A circle of 5ths, AKA +1 on the Camelot wheel, AKA harmonic
First we'll do the "I hate myself method" in steps
key is `deck master get_harmonic & param_equals "01A" ? get_text "02A" : `
if harmonic is 01A then +1 is 02A, because we're inside ` ` the filter is given what the script inside evaluates to, so get_text the value you want.
So go nuts, there's only 24 possibilities
key is `deck master get_harmonic & param_equals "01A" ? get_text "02A" : deck master get_harmonic & param_equals "02A" ? get_text "03A" : ...`
do that for 01-12 for A and carry on for 01-12 B and that's it, it's ugly but it works.
If you do it like that you'll get bored by your 6th copy paste, hopefully bored enough to think "there has to be a better way"
So a better way then,
how do we add 1 to the harmonic and for the case of 12X loop round to 1? we best try some stuff, [play along at home because I'm not going to give you the final filter]
load up a track with any key and open your custom_button editor, use this as the name
`get_harmonic`
that gives our current harmonic, not what we want yet, try adding 1
`get_harmonic & param_add 1`
same result, that doesn't work, try the other way of adding
`param_add get_harmonic 1`
different result, wrong answer, it's put a 1 in front of our harmonic
it was understood as a string, let's try cast it as an integer then add 1
`get_harmonic & param_cast 'integer' & param_add 1`
well we added 1 but a few issues, and this depends on you starting harmonic as to what you see
first off obvious, we're missing the A or B
now if your starting harmonic was 09X, 10X or 11X that's the only issue you'll see
but if it was less than 09X you'll see you lost your leading zero. or if your start harmonic was 12X you now have 13
let's deal with the leading zero, param_cast '00' will cast a number with a fixed number of digits
`get_harmonic & param_cast 'integer' & param_add 1 & param_cast '00'`
that fixes our leading zeros issue, now to try add A or B with a query on the end
`get_harmonic & param_cast 'integer' & param_add 1 & param_cast '00' & get_harmonic & param_contains "A" ? param_add "A" : param_add "B"`
that doesn't work, go back a step can we actually add a letter to it, forget the query just try add a letter on the end
`get_harmonic & param_cast 'integer' & param_add 1 & param_cast '00' & param_add "P"`
we got an P there, must be the query at fault, let's try the query at the start and double up the script, one for A case one for B case
`get_harmonic & param_contains "A" ? get_harmonic & param_cast 'integer' & param_add 1 & param_cast '00' & param_add "A" : get_harmonic & param_contains "B" ? get_harmonic & param_cast 'integer' & param_add 1 & param_cast '00' & param_add "B"`
That works, now just the issue of starting with harmonic 12X gives 13X
this is where I'm not going to give you a copy paste
if we know get_harmonic & param_contains "A" ? is true, the only thing we need to know after that is get_harmonic & param_contains "12" ? if that's true we want 01A, and I already covered that in the long boring method, : if it's false then do the other stuff.
we've got to ask the same contains 12 question after get_harmonic & param_contains "B" ? as well, but that's all there is to it.
if you've done that right your custom_button name will be == starting harmonic +1
that custom button name is what you paste into a filter that starts
key is
one tiny difference though, custom_buttons know what deck they belong to, filters follow the selected deck unless told otherwise, so when you paste it in to the filter, just after the opening ` specify deck master just before the first get_harmonic
I've told you everything here except the answer explicitly, the whole jigsaw is built up into only a couple of separate pieces, just put them together, or use the horrible way.
Or if time is money for you, I can work on those terms too.
[wow that got lengthy, but to do scripting you have to put some effort in, there won't always be a copy paste solution given]
Posted Sun 05 Nov 23 @ 1:59 am
Hey yall, my name is Big King Zilla, I just started DJing on Twitch because I figured out how to DJ using virtual DJ with my wheelchair. I am physically disabled so it pretty awsome but im trying to figure out how to do some more complex scripts for the custom buttons for better transitions that are a little more elaborate not to simple. Right now I am trying to figure out how to eq_kill_low & filter 25% & effect_active 'reverb' & mix_now 16bt but I cant get the effects to turn off automatically after I transition . If anybody can help me out I would really appreciate it.
Posted Sat 11 Nov 23 @ 7:17 am
using a wait 16bt & then calling effect_active off would be easiest.
Posted Sat 11 Nov 23 @ 7:31 am
hi at all, i have this question: i have a playlist named “Sequencer” (in browser i have seen that is a file.m3u) and this is my script:
get_browsed_folder_path & param_cast & param_contains ‘Sequencer’ ? browser_remove : playlist_add
because only in Playlist Sequencer (or folder Sequencer?) i would remove songs…in other folders i would add songs in Automix..doesn’t work (i think problem is that “Sequencer” isn’t a folder, but is a Playlist
Can you help me with correct script? Thanks
Posted Sun 12 Nov 23 @ 6:45 pm
check with a custom_button LED logic
get_browsed_folder_path & param_cast & param_contains 'Sequencer' ? on : off
does it work there? also check capitalisation, also check your ' marks, vdj does not like curved ' " like you have typed here.
Posted Sun 12 Nov 23 @ 7:47 pm
yes, correct thanks! my ‘ wasn’t right, now it works
Posted Sun 12 Nov 23 @ 11:43 pm
hi at all! script: linein 3 get_haslinein ? on :off
doesn’t work :( i would know if is there only linein 3 in audio setup
can you help me? thanks
Posted Wed 06 Dec 23 @ 5:34 pm
probably not possible. get_haslinein ? on : off is the best there is.
Posted Wed 06 Dec 23 @ 10:04 pm
Hi vdjscript Community,
I'm seeking advice on a specific VDJScript challenge. My goal is to apply the same type of filter effect on different stems within a track, but with varying intensities for each stem. For example, applying a filter to the kick drum stem at one intensity level while applying a different intensity of the same filter to the vocal stem simultaneously. I'm considering whether the 'effect_stems' command can be combined with the 'filter' command for this purpose. Has anyone successfully achieved this kind of independent stem-specific filter control? If so, how did you script it?
Any advice or shared experiences with similar scripting challenges would be greatly helpful.
Thanks a lot!
Thanks a lot!
Posted Thu 07 Dec 23 @ 12:45 am
