That's a good question.
since the 56 BPM needed to raise the 124 BPM track to 180 is about a +45% change..
vs
the 34 BPM decrease needed to lower the 124 BPM to 90 BPM .. about a -27% change.
so would seem the latter, would be preferable.
and on the other hand.. a track sounds much better pitched up (lively, higher energy), then pitched down (dragging)
OR
not that I understand this reasoning, but if one used the 180 and 90 to calculate the percentage differences (instead of the 124 BPM)
then going to 180 would be a +31% pitch change (56/180)
and going to 90 would be a -37% change (34/90)..
so by this reasoning the math, chooses going to 180 ?
its all good in the end
vs
OR
Posted Wed 27 Sep 23 @ 2:17 am
vs
OR
vs
OR
i seem to always find a way to break things...
but this is the very first transition i tried with this effect.
i think there would want to be some built in safe guard to prevent doubling/halfing, although im not sure exactly what that would consist of.
Posted Wed 27 Sep 23 @ 8:46 am
OK I think i figured it out.
track A was 93bpm, track B was 124
i think the effect is designed to take the shortest route which in this case was actually 93-62 bpm (31bpm vs 32bpm difference between 93 and 124)
so by just pitching track A up to 96bpm, then 96-124 for example, becomes the shortest route (28bpm)
i dont know though, if there could be some measure in place to avoid this, there may be some situations where you might want this? but you dont want it happening by accident either, perhaps a preview of what direction its planning to go? its a strange one.
Posted Wed 27 Sep 23 @ 11:24 am
Another problem with auto double/half the BPM is when you use Automix and prepared all mix points eight bars before vocals for example and now the eight bars become sixteen bars instead. This should be possible to fix by temporarily automatically moving the mix points the required amount bars forward or backward. Or if that isn't possible, I would like to disable this function per song.
Posted Wed 27 Sep 23 @ 11:38 am
Hello, is there any reason why in the mapping for the XDJ-1000MK2 during the SHORTCUT event (press BROWSE-SEARCH on the lcd) during the script
is #shortcut still 0?
controllervar '#shortcut'
Posted Sat 30 Sep 23 @ 10:37 pm
Hi seeing as you can't auto backup in increments of less than one day, is there a way to trigger the tidy auto zip backup via script ( or on demand?). Thanks, is a great feature.
Posted Fri 06 Oct 23 @ 9:15 pm
You know about the database backup from the "Browser Options" menu dot ?
(can create a backup as often as one wishes, there)
Posted Fri 06 Oct 23 @ 10:35 pm
@Mr T a l 0
automatically looks like it's just called on startup and if today's date exists it doesn't make a back up, despite making the setting 0.00000001 days
currently as IIDEEJAYII says, manually is the only way.
probably for the best.
Posted Fri 06 Oct 23 @ 10:41 pm
Thanks both. Manual it is then.
Posted Fri 06 Oct 23 @ 10:45 pm
Another challenge. Let's assume you have several tracks playing. If you want to manual increase the tempo of the currently selected track, how can you speed up the other tracks at the same rate to match the tempo change.
Posted Sun 08 Oct 23 @ 5:47 pm
Is:
deck all pitch XX%
what you are wanting to do with the script?
deck all pitch XX%
Posted Sun 08 Oct 23 @ 5:53 pm
pitch_lock on
move slider, deck whatever pitch +/- %
pitch_lock off
pitch_lock off
Posted Sun 08 Oct 23 @ 5:56 pm
Thanks both, "deck all pitch +1%" looked like what I wanted but it appears to increase the track by the percentage of the tracks analysed root BPM, rather than the currently playing tempo e.g 110 BPM. If one track is originally 98bpm, another 100 and another 110 then the increase in tempo is less than the others when pushed to 120bpm. Perhaps this can't be done via script?
Posted Sun 08 Oct 23 @ 6:30 pm
if they're out to start with, what where you expecting?
try
pitch +0.1 bpm
try
pitch +0.1 bpm
Posted Sun 08 Oct 23 @ 7:20 pm
or using Locodogs first suggestion.. (as I am not sure what you are wanting)
Does:
pitch_lock on & deck all pitch +1% & pitch_lock off
work for your button?
PS
that may be redundant with pitch_lock and deck_all pitch
Does:
PS
Posted Sun 08 Oct 23 @ 7:23 pm
Thanks both. Deejay that is perfect and equivalent to what I was trying but didn't work "deck all pitch +1% BPM" (unless I messed it up somehow).
Posted Sun 08 Oct 23 @ 7:46 pm
Hey scripting Gurus !
Is it possible to query a specific Cue position like we do with Song position ?
Example: I use :
Example: I use :
songpos_remain 10000ms ? blink 250msto blink a LED when it remains less than 10 seconds to a track. That's usual stuff already done on jogs wheels. Now, what I'd like to do is change the color or blink a specific Cue pad, but when the played track is approaching that cue location, a bit like a :
cue_pos_remain(I know this one doesn't exists as is..) Is that something that can be done in any way with the existing :
cue_pos?
Posted Thu 12 Oct 23 @ 2:24 am
Seems a question worthy of a lesson
Let's work this one out, cue_pos indeed looks like the thing we'll use
list of verbs wrote :
"cue_pos 1" returns the position of cue point #1 as a percentage "cue_pos 1 msec", "cue_pos 1 sec", "cue_pos 1 min" returns the position of cue point #1, msec, sec and min parts "cue_pos 1 mseconly" returns the position of cue point #1 in milliseconds "cue_pos 1 beats" returns the position of the cue point in number of beats from first beat
put this as a custom_button name, it will show you what it returns
`cue_pos 1`
it returns a percentage..., song_pos returns a percentage too, but that gets messy, 5% of 1 minute is going to give different results to 5% of 2 minutes. So let's not use that.
try this as the custom_button name
`cue_pos 1 mseconly`
cue_pos 1 mseconly that returns milliseconds, BUT One thing about cue_pos is that it returns ABSOLUTE values, it doesn't take pitch into account, we can prove this by moving the pitch slider around and our custom_button name stays the same,
That's going to mess us up too, a few hundred ms this way or that way might not matter but we can do better, cue_pos 1 beats, seems best
Let's look at getting our beat position
in the script window since we want to get something a good idea is type
get_
lot of verbs in that list, let's narrow it down
get_beat
still a few to chose from, looking at each description
get_beatpos is what we want.
Ok now we're comparing apples to apples, how are we comparing
Thinking out loud
if get_beatpos is bigger than (cue_pos beats - 16) [ 16 beats before]
That as script
get_beatpos & param_bigger 'cue_pos 1 beats & param_add -16' ?
Also thinking out loud
but also get_beatpos is smaller than cue_pos beats
That as script
get_beatpos & param_smaller 'cue_pos 1 beats' ?
put them together
get_beatpos & param_bigger 'cue_pos 1 beats & param_add -16' ? get_beatpos & param_smaller 'cue_pos 1 beats' ? on : off : off
put it on a custom_button and move the playhead around to test the LED logic.
It works!
There are other ways to do the compare but they take more typing, but if you were being fussy to only have 1 question mark [more advanced]
param_equal `get_beatpos & param_bigger 'cue_pos 1 beats & param_add -16' && get_beatpos & param_smaller 'cue_pos 1 beats'` 1 ? on : off
what does the bit before the && evaluate as, and what does the bit after && evaluate as, if both are the same, [and this case only both being true is possible for them to be the same] then the stuff inside the ` ` will return true, aka 1
Another way, over complicated for this case, more for queries of some of a few
param_equal `param_add "get_beatpos & param_bigger 'cue_pos 1 beats & param_add -16'" "get_beatpos & param_smaller 'cue_pos 1 beats'"` 2 ? on : off
Posted Thu 12 Oct 23 @ 4:31 am
Wow that was so much help, thank you !
I ended up having to add another " : " at the end to make that work on my DDJ-RZX Cue pad the way I wanted it. For my workflow, I only want a visual reminder when my Cue #7 is getting close (16 bt is fine). The way it's now set up, the pad color is steady lit with the cue default color, but flashed black -16 beats before it is reached. Yeah !
Thank you so much for your help :-)
get_beatpos & param_bigger "cue_pos 7 beats & param_add -16" ? get_beatpos & param_smaller "cue_pos 7 beats" ? blink 500ms ? color "black" : cue_color 7 : cue_color 7 : cue_color 7
Posted Thu 12 Oct 23 @ 3:25 pm
No problem, it just seemed like one of those were the full thinking process could be spelled out.
The figuring it out from documentation and not getting hung up on every verb or nested queries.
I've added it in to the page 1 of links in this thread just after doing bigger smaller comparisons [~800 post difference in time, but as topics go they follow each other quite well.]
Posted Thu 12 Oct 23 @ 3:54 pm
