I'm going nuts here trying to sort this issue out so I'm hoping someone can help me out.
If I perform a search for a song in the results I have many files listed which are not actually there. If I load one of them I get the ERROR message. If I activate the 'Exists' column it says 'yes' to every file (even the missing ones). Only when I load that file and get the error message does the 'yes' disappear. If the exists column picked up correctly the files that were not there I could delete them in one go. There are far too many to do them one by one.
Hope that makes sense. Can anyone help please.
Posted Fri 11 May 18 @ 12:26 pm
Clean database function
If you don't know how search online manual for information.
Posted Fri 11 May 18 @ 12:54 pm
Thank you so much. That worked and it's no longer doin' me head in!
Posted Fri 11 May 18 @ 1:28 pm
