Topic: Load different mappers settings on the fly
I've practically used up all my single keys so i created different mappers. Same sense as scrolling through sampler banks, is it possible to load a different mapped key settings on the fly?
Posted Tue 08 May 18 @ 11:42 am
No, there is no action to do this.
Workaround:
What you could do is to have a single mapping but use variable(s) and execute one action when true and another when not.
Example: Use a button to toggle (true/false) a variable...
toggle "$mysetup" (use any name, just have the $ at the beginning)
Then each button can have ...
var "$mysetup" ? ActionA : ActionB
the button will execute ActionA if the variable is true and ActionB if not
What I sometimes do is put the functionality on pad pages, and then use the function-key pad-page mapping (keyboard to pads)
And then I only map keyboard keys to select specific pad pages
Thanks for the response. If you have time please PM me the steps.
I hope it's ok if I just post them here
First step is to map something to the pads. I suggest using the pre-made "keyboard to pads" definition from the download section:
https://virtualdj.com/plugins/?category=other&search=pads+to
I made a video about it recently:
After that you can skip between the pad pages using F9 and F10 and trigger the pads with F1 - F8 and shift+F1 - shift+F8
You can also map keyboard keys to take you directly to a pad page by add the script pad_page <name>, like pad_page 'hotcues'
You can also make a pad page page that is simply an index pad page for other pad pages.
I show that in this video:
After that you just need to add all the script you like to custom pad pages. I made a video about custom pad pages a while ago:
Here are few examples of custom pad pages I've made, and which I can trigger using this setup:
You could always use the modifier keys
Shift+key
Or
Ctrl+key
Or even
Ctrl+shift+key
Not initially as simple to press as a single key but i know with practice these combos become second nature.
Like I have a,s,d,f to call beatgrid on/off slots 1 to 4, shit+ those keys calls slots 5 to 8 check your mapping if you could free up some keys
( i know its hard to reprogram your brain when a key has been one command for years, I've a controller launchpad 2 reloop neons and i still use the keyboard, old habits die hard :-) )
