Is there a way to read the comment field if it is extra long, or on multiple lines. You used to be able to click on it and it would show. My medleys I have listed the different songs in the track and can't see them now, just the first part - suggestions?
Posted Wed 21 Mar 18 @ 3:28 am
Set "browserTextFit" to smart in options.
Posted Wed 21 Mar 18 @ 4:12 am
It was - see in the comment i have multiple lines - before you could scroll down in tag editor and I found another way a while ago but forgot
Posted Wed 21 Mar 18 @ 4:26 am
I'm sorry, I thought you meant in the browser. Which build are you using, because I can't get mine to go to multiple lines. It just keeps going, even though I would never have that much information in any field.
Posted Wed 21 Mar 18 @ 5:12 am
latest build
I have some awesome mixes/medleys and have the different songs in the medley listed in the comment field and you use to be able to look at it by double clicking or looking in tag editor - now I can't find anyway to look at it. Any suggestions?
Posted Fri 23 Mar 18 @ 2:34 am
Doesn't the scroll wheel work?
Posted Fri 23 Mar 18 @ 6:19 am
In the tag editor you used to be able to view all of it - did that change on the last build
Posted Sun 25 Mar 18 @ 10:56 pm
Duplicate topic, continue discussion here:
https://virtualdj.com/forums/223970/General_Discussion/Comment_Field_-_Tag_Editor_make_longer_____.html
Posted Wed 25 Jul 18 @ 8:49 am
