Hi ,is there another programme so that I can manage my music play list on a USB drive ...other then Rekordbox.....since that programme only works with Pionner controller......and I do not have a Pionner controller ......I have a Numark mixdeck quad....thanks
Posted Sat 03 Mar 18 @ 2:11 pm
Maybe try Virtual DJ...
Posted Sat 03 Mar 18 @ 2:14 pm
Maybe my question wasn't clear.......I do have virtual DJ pro.....my controller now is Reloop Beatmix....im looking to change my controller to Numak Mixtrak Quad.........to be able to play or add other source of music in case my computer as a problem and I need a back up......so my questionis If I download on my USB drive all of my library that is in my Itune .....will it work with my new controller....like Rekordbox works with Pionner??? thanks
Posted Sat 03 Mar 18 @ 3:10 pm
No - sorry, I still don't understand what you're asking.
You first said that you have a Mixtrack Quad. Now you seem to be saying you haven't got it yet...
It doesn't matter whether your music is on a USB drive (do you mean a flash drive, or an external HDD?) or on the computers internal HDD. It will still work with the controller, via VDJ.
So if the Quad is your main source of music, what's the backup you mentioned?
Posted Sat 03 Mar 18 @ 4:19 pm
ok thanks you have answer my question....thanks
Posted Sun 04 Mar 18 @ 5:26 pm
