I am using the Pioneer XDJ-R1 with Virtual DJ 8 Pro on a Windows 10 notebook. This past weekend, I would lose audio output while playing and my controller would show "Not Connected" on the displays. I would have to power off the controller, reboot VDJ and reconnect midi again before working once again but then to it happening all over again. It did this 3 times in one hour to be exact!! Anyone else has had this problem before? Is it a controller, VDJ or a windows issue and how do I determine it?
Thanks,
Scott
Thanks,
Scott
Posted Mon 19 Feb 18 @ 7:59 pm
I would try a new USB cable first, also check your PC is not putting USB ports to sleep to save power.
Posted Mon 19 Feb 18 @ 8:04 pm
