Hello, guys. I bought VDJ 8 for the controller. My computer have driver for the device. After logg and conect the hardware i can not using the controller because did not response. What is the problem?
Posted Sat 10 Feb 18 @ 3:33 pm
its not supported yet
if you look here https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
it says Coming Soon which means not supported yet.
Posted Sat 10 Feb 18 @ 3:39 pm
So way VDJ sells something they do not have?! When will be available? Any information?
Posted Sat 10 Feb 18 @ 4:04 pm
You can download vdj build 4064 here:
https://virtualdj.com/download/build.html
After updating it should recognize your roland dj 202.
Posted Sat 10 Feb 18 @ 4:09 pm
What do you mean? Have you found a place saying that VDJ now works with the Roland DJ 202?
EDIT:
I see it now.
It's on the VIRTUALDJ HOME PLUS license dropdown
And also in the controller dropdown in the software:
Posted Sat 10 Feb 18 @ 4:26 pm
yeah somebody forgot to update the controllers page lol
the 505 is in there too now so it seems. wonder if any of the other coming soon controllers work now?
Posted Sat 10 Feb 18 @ 6:33 pm
Thank you everyone for the replies. My controller now work :)
Posted Sat 10 Feb 18 @ 10:46 pm
Is the sequencer working aswell?
My Controller is working fine in this early acces mode but the sequencer isn't outputting any sound. It doesn't appear under audio outputs either.
Maybe this will be added in a later build or am I missing something ?
Posted Sun 11 Feb 18 @ 8:50 am
The sequencer mode did not work if you want to make a beat and press start button. Works only if you want to play his sounds in real time. I hope you understand what i explained :D :D :D .... my english is not very well :)
Posted Sun 11 Feb 18 @ 9:26 am
For the sequencer (for both 202 and 505) , you will need to wait for the next Early Access Build.
A new feature had to be implemented, but since the next Early Access may be delayed, we thought we should proceed and provide support for both of them (but without the TRS) in the current EA
Posted Mon 12 Feb 18 @ 1:17 am
