Greetings....
Heres my problem.....
Im working with :
windows 7....
Mixtrack pro 3
behringer xenyx302 usb mixer
teknmotion headphones with built-in mic...
Both my headset & attatched mic is goin in thru the mixer...(Im only using the controller to mix).......And the xenyx mixer is set up in & out thru the pc......
The sound is great....Clear and crisp...
But.....Im hearing my own voice.....With echoes ...
I cant figure how to minimize my voice in playback while pushing out a crisp sound with my voice...
Please help....
Im working with :
windows 7....
Mixtrack pro 3
Please help....
Posted Sat 10 Feb 18 @ 8:07 am
Firstly, please stop SHOUTING.
What you're experiencing is called latency, and it's caused by the time the computer takes to process the audio. This tends to happen on cheap domestic/consumer equipment.
It can be avoided by using professional audio equipment that has specific low latency performance (i.e. it uses an ASIO driver on PC).
Posted Sat 10 Feb 18 @ 8:46 am
Use this setting. It will eliminate the feedback.
Posted Sat 24 Aug 19 @ 1:38 am
