Hello, im just started using trial version to test out the software but apparently CPU usage easily gets maxed out when loading a track on decks. Thank god its not interrupting the sound playback. My laptop specs are as below :
Dell laptop
core 2 duo 2.5ghz
4gb ram
150gb hdd
windows 7 ultimate 64bit
Isn't that more than enough to play? Or i need more ram? Please advice. Its a freshly installed windows with no other software's.
Dell laptop
core 2 duo 2.5ghz
4gb ram
150gb hdd
Posted Sun 21 Jan 18 @ 5:43 am
If you want loading to go slower you can set loadpriority to idle.
But if you don't have any dropouts, I'm not sure why you don't fully want to use your cpu
Posted Sun 21 Jan 18 @ 9:32 am
If it's ok Adion......he can go to this link where it shows how to make his laptop reach it's full potential. It's the Dubspot blog. http://blog.dubspot.com/optimize-your-windows-7-pc-for-djing-music-production/
Posted Sun 21 Jan 18 @ 3:34 pm
Dell laptop
core 2 duo 2.5ghz
4gb ram
150gb hdd
Dell laptop
core 2 duo 2.5ghz
4gb ram
150gb hdd
I would upgrade the HHD to Sold State Drive SSD a 256GB or even 180 should be ok in your case
Upgrade the RAM to 8GB and then reinstall windows and also dell updates/patches (bios, firmware etc from Dell Support)
Posted Fri 26 Jan 18 @ 4:00 pm
