I tried RB when it 1st came out. It was horrible. I'm sure Pioneer has improved it quite a bit by now. I have read its a resource hog so I'm gunshy using it live.
Posted Tue 23 Jan 18 @ 8:48 pm
I think, RB is not the Problem.
The Software is "OK", but for me VDJ ist the best.
I will use RB as long as i Need, but if VDJ has got the mapping for the Controller, i will Change back to VDJ.
Hope they will work faaaaaaaaaaaaaaaaaaaaast.
Posted Wed 24 Jan 18 @ 6:43 am
Hi,
Do someone know if the pads are pressure sensitive?
Posted Thu 25 Jan 18 @ 5:01 am
LDJMax wrote :
Hi,
Just saw a reviews video, and yes they are pressure sensitive
EDIT: Sorry that was the jog wheels (being pressure sensitive, and not touch sensitive like on most controllers)
Posted Thu 25 Jan 18 @ 8:29 am
It looks like the hardware effects is sending info to the software (Rekordbox by default) and use the software effects, when a laptop is connected
So I guess that (theoretically) makes it possible for VDJ mapping/control of the effect "channel"...
Posted Thu 25 Jan 18 @ 9:19 am
Could you use the mixer in hardware mode and the decks in midi?
Posted Thu 25 Jan 18 @ 9:27 am
According to this interview from NAMM the beat effects are fully hardware effects...i wonder about release fx because I don't see enough on the controller to be hardware fx.
https://m.facebook.com/story.php?story_fbid=1829772967063821&id=114193768621758
Posted Fri 26 Jan 18 @ 12:54 am
seems its already for sale outside of the USA
Posted Fri 26 Jan 18 @ 8:31 pm
ive applied for finance on one but pretty sure i wont get as ive been turned down once before but heres hoping
if not the credit card it is
Posted Sun 28 Jan 18 @ 7:55 am
Expecting delivery of the DDJ-1000 tomorrow, 1st thing ill try is mapping it to VDJ. I’ll post the results
Posted Mon 29 Jan 18 @ 10:32 pm
sweet post up some clear pics!
Posted Mon 29 Jan 18 @ 11:18 pm
nice one look like ive been accepted for finance so should have one by next week myself
Posted Tue 30 Jan 18 @ 6:27 am
Ok, So my DDJ-1000 is plugged in, connected to my PC laptop which is running Virtual DJ 8
Initial things to note
- very pretty device (I had a DDJ SX before and the larger wheels are impressive)
- Out of the box nothing works with Virtual DJ8
- VDJ sees it as a custom controller and creates an empty custom mapping
- I have successfully mapped Cue & Play/pause
- Stuck now with crossfader
- If i move the crossfader the detected midi shows all of the following:
6-ENCODER31
6-JOG31
6-SLIDER31
6-SLIDER63
6-JOG63
6-ENCODER63
I have tried mapping 6-SLIDER63 to crossfader, but the result just makes the crossfader jump around randomly
Anyone can help me on this ?
6-ENCODER31
6-JOG31
6-SLIDER31
6-SLIDER63
6-JOG63
6-ENCODER63
Posted Tue 30 Jan 18 @ 7:09 pm
Try this
click for DDJ-1000 MIDI data PDF
Posted Tue 30 Jan 18 @ 7:56 pm
Seems like there is a new version of the midi map doc..
https://pdj-ecom-cdn.azureedge.net/-/media/pioneerdj/software-info/controller/ddj-1000/ddj-1000_midi_message_list_e1.pdf
This is what it says for the crossfader
I'm no midi expert, but it looks like the channel should be 7 whereas I am getting 6
6- SLIDER63
Am I supposed to limit the range to something between 31 & 63 somehow ?
6- SLIDER63
Posted Wed 31 Jan 18 @ 5:47 am
Actually VirtualDJ starts counting MIDI channels from 0 while the doc starts from 1. Therefore it's ok to see 6 on VirtualDJ when 7 is mentioned on the doc.
On the other hand, the crossfader is 14-bit MIDI. In other words it sends 2 messages, not one.
With simple MIDI wrapper you can't use 14-bit MIDI (2 MIDI messages for a single element). You'll have to use only the MSB (Most Significant Byte) which means 6-SLIDER31 element
If you wish to use 14bit MIDI (and take advantage of the higher resolution it offers) then you need to create a proper device definition.
Posted Wed 31 Jan 18 @ 6:54 am
Given what we now know about the controller and how popular it is, how likely is native support looking?
Posted Wed 31 Jan 18 @ 1:52 pm
I'm sure the VDJ engineer will do their best to natively support this controller.
But it'll depend on how hard it is to "unlock" the controller.
Posted Wed 31 Jan 18 @ 3:59 pm
hrdnx wrote :
Quote
"The DDJ-1000 comes with a Rekordbox DJ licence, and it’s compatible with Rekordbox DVS, meaning you can connect your turntables or media players to spin with timecode vinyl / media.
It also works as a standalone mixer, meaning you can run audio without a laptop: there are four pairs of switchable RCA phono / line inputs for hooking up turntables and DJ media players like CDJs or XDJs. You also get two microphone inputs, two USB jacks for hooking up two laptops, XLR and 1/4″ master outputs and 1/4″ booth outputs."
Quote
But, I think you need to buy a Recordbox licence to activate the DVS...
Posted Thu 01 Feb 18 @ 12:36 am
Well a VirtualDJ representative said "real soon" on Facebook and that to me means days or weeks but who knows.
Posted Thu 01 Feb 18 @ 12:48 am
