I love the fact that new layouts can be added without the need to add graphics to the bitmap file. :-)
May I suggest that the rhythmwave is made the same height as the deck, and the transport buttons positioned vertically between the windows...
Posted Sat 05 Oct 19 @ 7:26 am
Version 5 is now available with 2 new variations, 6 Decks (2 +4 mini) and a Single Deck for preparations, Automix, Single Player etc
Single Deck
Single Deck
Posted Fri 08 Nov 19 @ 4:06 pm
Much in love with Blocks skin. There are many variations possible for all to work with.
The 4 decks with mixers is my favourite. I use it as a Independant radio dj to have the same playout system on several stations with different automation and Music libraries.
What i hope that it will added and be possible in the 4 decks with 4 mixer panel is that i can toggle off the horizontal waves as it take up a lot of screensize for my needs.
Posted Fri 22 Nov 19 @ 10:31 am
I have this skin on my desktop and laptop. There is no cross fader on the desktop one.
Both are set up the same.
Posted Mon 13 Jan 20 @ 7:52 pm
No they're not. One has the mixer enabled. The other doesn't.
Posted Mon 13 Jan 20 @ 8:11 pm
Did a reinstall and it's okay, so I can't verify if mixer was not enabled.
Thanks
Thanks
Posted Mon 13 Jan 20 @ 9:08 pm
You can - check the icons in the images you posted.
Posted Mon 13 Jan 20 @ 10:51 pm
Got it. Do not recall changing it.
Must have though.
Thanks
Must have though.
Thanks
Posted Tue 14 Jan 20 @ 3:21 pm
It look the waveform for track is very hard to see color after update for 2021 . can this be adjust ?
before new update of VDJ it very bright and easy see . now color very dark.
thank you any help .
Posted Wed 05 Aug 20 @ 12:58 am
