Denon MC4000 XLR master output (R) volume sound lower compared to the (L) XLR output when connected to speaker. I concluded after swapping cables and speakers.
How do you fix a problem like this when both (L) & (R) out to speakers are expected to sound the same level when knobs are the same position?
Posted Thu 28 Sep 17 @ 3:06 am
Is that with all of your tracks ?
The only software parameter i can think of is the Master Balance. Just to make sure its on 50%, assign a custom knob on the skin as master_balance and see if its on the middle.
If it is, then i suppose you need to contact with Denon Support, as it appears to be a hardware issue.
Posted Thu 28 Sep 17 @ 7:23 am
Yes, all tracks.
I did try "master_balance 50%" on a custom button on the skin, still issue prevail.
When you say "see if its on the middle" where, what am I looking? thx
Posted Thu 28 Sep 17 @ 12:47 pm
Assign the custom knob on the default skin and you will be able to see if the positition is in the middle
Posted Thu 28 Sep 17 @ 1:06 pm
My error.
Its knob to be mapped not button and it does show 50%.
I will contact Denon.
Thanks boss.
Thanks boss.
Posted Thu 28 Sep 17 @ 3:06 pm
καλησπερα.το ιδιο προβλημα εχω και εγω με την denon mc4000.δεν ξερω τι μπορει να φταει..το balance το εχω και εγω στο 50%.
Posted Sat 02 Dec 17 @ 7:46 pm
This is an English speaking forum only. Please ask your questions here, thank you.
Posted Wed 06 Dec 17 @ 8:09 am
