Doing a typing search of "KEYCUE" in the Download Add-On section results in zero find. Has the pad been deleted?
Posted Thu 22 Feb 18 @ 11:30 pm
Possible since a version of it is now included in VDJ by default. It's the last one described in the manual
Posted Fri 23 Feb 18 @ 1:14 am
could this be what u want? https://virtualdj.com/plugins/?addonid=80399
Posted Fri 23 Feb 18 @ 11:17 am
KeyModPlay is indeed a replacement but the query was it me that could not find Keycue?
Posted Fri 23 Feb 18 @ 11:35 am
It has been put into the product as a default pad page
Posted Fri 23 Feb 18 @ 11:57 am
Anybody else having problems with the roland 202? For instance, my fader doesn't cut all the way off on the right side only, in the scratch settings, but works in the fade settings.. odd
Posted Sat 24 Feb 18 @ 5:08 am
..Had my first total freeze up and have to reboot too
Posted Sat 24 Feb 18 @ 5:10 am
Well hope this does'nt happen to me when i get one but..you should post your computer specs and configurations..other that ..get a license ,run the real deal..cracks will fail...
Posted Sat 24 Feb 18 @ 9:04 pm
I wasn't able to repeat this error, have you got more information how and when this happens exactly ?
Posted Mon 26 Feb 18 @ 11:02 am
Please see my post and the temporary workaround at https://virtualdj.com/forums/222496/VirtualDJ_8_2_Technical_Support/Roland_505_DJ_controller.html It also affects the DJ-202
Posted Tue 27 Feb 18 @ 8:13 am
So only issues with the 505 and 202? not the 808?
Posted Thu 01 Mar 18 @ 9:34 pm
Hi, does anyone knows if the Rolland 202 is now available for using it with vdj? And what version do I need?
Tanks
Tanks
Posted Sat 07 Jul 18 @ 9:35 pm
Yes it is. In the future, you can check here to check on supported controllers.
Posted Sat 07 Jul 18 @ 9:43 pm
Thanks A Man and His Music. Do you know what version do I need?
Posted Sat 07 Jul 18 @ 10:18 pm
Just download the current version. Why would you want to use an old version?
Posted Sat 07 Jul 18 @ 10:25 pm
Well, I think that I need to have an Earlier Access Build with a superior version. But thanks a lot bro.
Posted Sat 07 Jul 18 @ 10:30 pm
it works fine with the current release on the home page
Posted Sun 08 Jul 18 @ 3:14 am
bonjour oui moi jais acheter controleur dj roland -202 ya quel que jour je me suis rendu sur www.roland support sur serato lite intro jais télécharger version lite gratuite comme il dise il deconais le programme bug impossible configuré conrectement tres male presenter les confiruation
ensuite je suis revenu ici télécharger virtual dj demo les nikel pour quoi mette t il télécharger Se logiciel gratuit mes il ne mette meme de tuto pour montrer les suivis ,,,,,,,je vais achete virtal avec licence mes je voudrais quand meme avoir ma version gratuit punesse
Posted Sun 30 Sep 18 @ 11:03 am
This is an English speaking forum, please try our French forum located here, thank you.
Posted Wed 03 Oct 18 @ 8:34 pm
