Feeling a bit confused this morning about the Audio settings on my system. I use Virtual DJ 8 with a HP Laptop. Denon MC4000 Controller and Alto TS250 Speakers. What is the ideal Volume / Gain Levels. I have the volume on the laptop at 75% The Master on the controller at 50% the gain on the controller at 50% and the speakers set at about 10am or 75% what is the ideal levels any help would be fantastic.
Posted Wed 05 Jul 17 @ 7:24 am
It's impossible to tell as there are so many variables. As long as the sound is clear and not distorted within the range you listen at then it's all good.
Posted Wed 05 Jul 17 @ 7:30 am
