please help me.
when ever i press play, vdj will automatically change my pitch all on it's own.
i tried every possible way to disable this and nothing works.
please advise.
thank you.
please advise.
thank you.
Posted Wed 07 Jun 17 @ 1:06 am
you need to go into your options in settings then scroll down to the audio section and look for auto key if on yes click no
Posted Wed 07 Jun 17 @ 3:14 am
tried it
problem still exists.
thanks for trying
thanks for trying
Posted Wed 07 Jun 17 @ 3:47 am
This normally works:
If it's on load you need to disable autoBPMMatch in the settings
If it's on play, you need to disable smart play on the deck. You can do it on the little dot under the pitch fader
If it's when you automix you need to disable autoMixBeatMatchOnFade in the settings
Posted Wed 07 Jun 17 @ 5:48 am
thank you so much. it worked.
Posted Wed 07 Jun 17 @ 6:05 am
