I have purchased new lighting, running in sound mode and it is just all over the place so to speak.here is what i have on a truss. 2 chauvet circus 2.0, chauvet gigbar irc, chauvet vue 4.1 and a shimp dl 22r laser. Any help on controll of these would be greatly appreciated
Posted Tue 06 Jun 17 @ 6:05 am
Check out the American DJ DMX bridge. if you have and Iphone or Ipad you make all the programing on your device and control your lights wirelessly via a closed Wi-Fi network. It also allows for live control and preset that can be saved to buttons on your screen.
Posted Tue 06 Jun 17 @ 6:51 pm
If you want to continue to work in sound active, these units may have settings to control sensitivity. Alter the sensitivity of each light, so that they react differently from each other. Otherwise, you may want to look into DMX control.
Posted Tue 06 Jun 17 @ 8:26 pm
Will an obey 40 give enough controll , would like to set scenes as im still fairly new and learning to mix. Trying to keep myself on the mixer more than lighting
Posted Tue 06 Jun 17 @ 9:16 pm
You like Chauvet then? :-)
Yes, a DMX controller like that (of which there are many) will be more than adequate to control what you have.
Getting your head around the programming though is another matter. Some people find it very challenging.
Posted Tue 06 Jun 17 @ 9:22 pm
Take your time and do the research. The obey 40 will work fine, and give you the added ability to upgrade to more fixtures. However, also look at software options, which may be easier and have built in scenes for many of the lights on the market. There are some free options available to try out, but the paid for options will offer more features.
Posted Tue 06 Jun 17 @ 9:37 pm
I have all chauvet mostly because it was at an auction for damaged packaging and was deeply discounted i picked up the gigbar for 130 with no damage at all to the actual light, and i had looked into a few software programs.
Posted Tue 06 Jun 17 @ 10:24 pm
