Hello everybody.
I made a little mistake after recording a mixtape i accidentally hitted the record button again. now my mixtape is overwritten :( . Is there a way to get it back because i really need this mixtape?
I hope someone can help me!
regards Thijmen.
regards Thijmen.
Posted Mon 24 Apr 17 @ 5:32 pm
You could try a free software called Piriform Recuva. I guess if you have overwritten with the same file name it will be gone for good though.
Posted Mon 24 Apr 17 @ 5:35 pm
yeah i have panda recovery running right now. but i hoped there was maybe a temp folder of virtual dj somewhere or another way to get it back. maybe someone else knows a way :)
Posted Mon 24 Apr 17 @ 5:41 pm
If it's been overwritten by the same name then there's no way it can be recovered unfortunately.
Posted Mon 24 Apr 17 @ 5:57 pm
He needs to go into his setting and change the overwrite option to something else.
Posted Mon 24 Apr 17 @ 8:25 pm
if you are a windows user , you may be lucky and have shadow copy enabled on your system, right click on the file and select 'previous versions' , if shadow copy is enabled you may be in luck !
Posted Tue 25 Apr 17 @ 10:11 am
Unlikely (given how quick between create and overright) but worth a shot
Posted Tue 25 Apr 17 @ 12:02 pm
I'm pretty sure when you record with VDJ-8, and hit the record button, VDJ will move the original recording's file name to "name + (1)" or "name + (2)".
I really don't think you can overwrite in VDJ-8. Look in your folder to see if you see the duplicates with (1) or (2) ...
Posted Tue 25 Apr 17 @ 9:24 pm
You would think so,But I've been wondering Why it insist on keeping the same name and not add a "-_1"... so allways have to go into file before recording,and renaming..this is strange...
Posted Fri 28 Apr 17 @ 8:01 pm
Posted Fri 28 Apr 17 @ 8:17 pm
Hmm,so many hidden settings...thnx man...
Posted Fri 28 Apr 17 @ 9:13 pm
I don't know about Hidden Settings, it's right there.
Posted Sat 29 Apr 17 @ 12:56 am
Have'nt looked...thanks again
Posted Sat 29 Apr 17 @ 1:25 am
Too funny. The option search window actually has a dropdown menu. You can also just start typing a subject, and it will show you results. You may have to try a few different words, but the dropdown will give you all of the options.
Posted Sat 29 Apr 17 @ 6:51 am
