I am working on some mapping and just simply need the proper way to put a knob to set control the slot selection on the beatgrid regardless if it is in 3 fx selection or not.
Please.
Please.
Posted Tue 04 Apr 17 @ 1:36 am
the beatgrid audio fx?
Posted Tue 04 Apr 17 @ 5:36 am
yea. i'm using a ddj-sx2. i really like the beatgrid so instead of using it as one of my effects i have set the 4th knob (as a button) to toggle beatgrid on/off . would like to use the clockwise/counterclockwise rotation to change the set that the beatgrid is on. i usually have the config for tables 1-4 open in 2nd screen so i can see what set they are in before use. atm though unless set to effect 1-3 i cant change paremeters using a knob. So i wish to set the turning of 4th knob to change set.
i just want the one line of code to do such, preferably in a copy/paste-able form.
Much appreciated.
Much appreciated.
Posted Tue 04 Apr 17 @ 10:37 pm
param_bigger 0 ? effect_slider 'Beat grid' 1 +14.3% : effect_slider 'Beat grid' 1 -14.3% (for an endless encoder)
effect_slider 'Beat grid' 1 (for a knob)
Posted Wed 05 Apr 17 @ 3:41 pm
That first strip got it. Not all heroes wear capes. You're amazing. Thank-you.
Posted Thu 06 Apr 17 @ 4:55 am
