Hi guys,
I would like to program VDJ controller midi mapping to mute deck 1 (and deck 2) when I press FX1 Assignment button (or Fx2 assign for deck 2) of the Pioneer DDJ-SZ only while it is pressed to assist with scratching. So far I am using "Mute [While_pressed] but it toggles instead of muting only while pressed.
Can anyone help with this?
Darin
Darin
Posted Tue 28 Mar 17 @ 4:33 pm
deck 1 mute while_pressed
This worked for me on the skin at least.
Did you try it on another button, perhaps the FX assignment buttons don't send both press and release messages on your controller?
Posted Tue 28 Mar 17 @ 5:26 pm
Try this ...deck 1 level 0% while_pressed & deck 2 level 0% while_pressed
Thank you very much Adion. The phrase "deck 1 mute while_pressed" works perfect YAY!!!! :)
Posted Tue 28 Mar 17 @ 6:09 pm
Mann!!!!!! :) I don't know why I didn't think of this before. Its much easier than hamstering the crossfader. I LOVE IT :)
Posted Tue 28 Mar 17 @ 6:13 pm
how do I get my Hercules controller to work with virtual dj
Posted Tue 28 Mar 17 @ 11:08 pm
Connect it with USB to you computer. Install ASIO drivers. Install latest version of VDJ. Done.
Posted Wed 29 Mar 17 @ 7:55 am
