I'm having a bit of a problem with the connection between my PC and VirtualDJ Remote app. On my home network, everything connects perfectly; VirtualDJ is open on my PC, and I'll open the remote app, and it'll sync right up.
When I try to use it with my production computer, which is on a local network, the only way it will connect is if I manually input the IP and Port. Has anyone experienced this issue? Could it be something with the network security settings?
Posted Sun 26 Mar 17 @ 2:37 am
