When two controller devices connected play music(for example:PIONEER CDJ),In the case of don't need the Deck2(right),pull out the Deck2(right) control device,The Deck1 song will be stopped(Probability of sixty percent).
Maybe due to the core instability,And the Deck order often often upside down or changed.
Posted Sat 11 Mar 17 @ 4:16 pm
go to setting and u can set it #YourRIPgramma
Posted Sat 11 Mar 17 @ 4:18 pm
Perhaps in the Setting Tab Page - "VDJScriptGlobalVariables" $deck=1/2
Posted Sat 11 Mar 17 @ 4:24 pm
I know how to set these settings, I said that the problem is similar to the BUG, and the settings are irrelevant!!!!
I KNOW!!
Posted Sat 11 Mar 17 @ 4:29 pm
LOL
Posted Sat 11 Mar 17 @ 4:36 pm
It's not a bug.
If VDJ is running and using those devices, you should not be pulling out the cable of the device.
Posted Sat 11 Mar 17 @ 4:37 pm
groovindj wrote :
It's not a bug.
I know this is wrong, but I am not a DJ Fans, I am a Chinese Club DJ, I am faced with such use every day. In the replacement of DJ, the music is not stopped, the other DJ are using RANE, so the need to replace the computer and USB interface. CDJ has only one USB interface. Both TK and RANE can be pulled down, VDJ can also, just may appear to be playing songs to stop the accident!!!
Posted Sat 11 Mar 17 @ 4:42 pm
I found that either RANE or Mixvibes Cross or Traktor can be selected in the CDJ screen DECK, but VDJ can not be! I hope VDJ can also choose, so it is not easy to make mistakes!!!
Serato DJ
MixVibes Cross
TRAKTOR PRO
Serato DJ
MixVibes Cross
TRAKTOR PRO
Posted Sat 11 Mar 17 @ 6:00 pm
