I've searched high and low in the VDJ forums and Wiki pages and can't seem to find what I'm looking for. Can somebody please post a screen cap of the VDJ 8.x sound configuration for a pair of CDJ400s? Naturally i'll be using an external mixer (DJM-400). I'm using the windows version of VDJ 8.x. Also do I need to install any Pioneer drivers or will it be plug and play? Any help would be greatly appreciated. Thanks guys and gals!
Posted Tue 07 Mar 17 @ 2:46 pm
Have found this for Virtual DJ 7 with CDJ 400:
https://virtualdj.com/wiki/CDJ-400.html
https://virtualdj.com/forums/112427/Hardware_Technical_Support/How_to_set_up_2_Pioneer_CDJ-400_s_with_Virtual_DJ_5.html
Think this is there nativ supportet too in last Buildt of VDJ 7,but have not look.
VDJ 8:
and the Pioneer CDJ 400 is Nativ Supportet Controller in VDJ 8 ,he is in the List
(have look in VDJ 8.2 Buildt 3621)
Hope this help you
greatings,Dirk
VDJ 8:
Hope this help you
greatings,Dirk
Posted Tue 07 Mar 17 @ 3:47 pm
VDJ 8:
Hope this help you
greatings,Dirk
VDJ 8:
Hope this help you
greatings,Dirk
Appreciate the effort however this isn't what I'm looking for. Need a screen cap from version 8.x .... The sound setup in 7.x and 8. are completely different.
Posted Tue 07 Mar 17 @ 5:23 pm
No it really isn't that different. Obviously the appearance of the VDJ GUI has changed, but the settings you need are the same.
You need to use an external mixer setup, and select the output of deck 1 to feed the audio interface of CDJ #1, and the output of deck 2 ditto for CDJ #2.
I'm surprised you need to ask. You've been here almost as long as I have. :-)
Posted Tue 07 Mar 17 @ 5:40 pm
I'm old ... and lazy .... LOL!
Posted Tue 07 Mar 17 @ 7:56 pm
https://virtualdj.com/forums/193434/General_Discussion/connecting_my_lappy_to_cdj_2000_s.html?search=pseft&page=1
check this out bro, this is for 2000.
i use 400 and its pretty much plug and play
Posted Fri 10 Mar 17 @ 10:52 pm
Posted Fri 10 Mar 17 @ 11:01 pm
