SBDJ wrote :
There is nothing we can do to improve the loading time; that particular restriction is on Spotify's end.
In that case the Spotify plugin isn't really any use as the loading is just too slow. As I said before there's no chance of the track being fully loaded and analyzed because the previous track would be finished first.
Posted Thu 02 Mar 17 @ 3:43 pm
Warakurna wrote :
So Spotify makes a difference between VDJ and Djay Pro, because Djay Pro loads almost instantly.
I first trialed Spotify to test with djay Pro, and it works like a champ. I had hoped the same for VDJ. Seems we could have either,
the ability to cache files or experience a better load time. Is not enjoyable for home use through VDJ.
ce la vie.
Posted Thu 02 Mar 17 @ 3:48 pm
With all the new features, is there any explanation of how some of them work?
For the "Lookup empty year and genre from discogs in tag editor using option button"
I do not see any options button to try and look up year and genre.
And for "New filter word: duplicates"
How does this work.
How does this work.
Posted Thu 02 Mar 17 @ 4:00 pm
The discogs option is on the button beside the file name in tag editor.
I agree for new features there should be an "expanded" changelog explaining what they are and where to find them.
Posted Thu 02 Mar 17 @ 4:04 pm
Never thought of trying that one.
Thanks
Thanks
Posted Thu 02 Mar 17 @ 4:12 pm
How does this work.
How does this work.
You just create a new Filter Folder and write .. duplicates as Filter, and the Filter Folder will gather all of your duplicate files, in case you need to delete those.
Posted Thu 02 Mar 17 @ 6:37 pm
Thank you
Posted Thu 02 Mar 17 @ 9:10 pm
This assumes the files have exactly the same filename other ways it won't work.
Handy tool for some though!
Posted Thu 02 Mar 17 @ 9:22 pm
is there a way to dl build 3621 i am on currently 2573
Posted Thu 02 Mar 17 @ 11:02 pm
earlyAccessUpdates set to yes in options for latest builds.
Posted Thu 02 Mar 17 @ 11:21 pm
You can also download from here :
https://virtualdj.com/download/build.html
Posted Thu 02 Mar 17 @ 11:27 pm
many thanx guys
Posted Thu 02 Mar 17 @ 11:59 pm
Deezer is annoying me, when I load a song it tells me I need a premium subscription, which I have, anyway Spotify works.
Posted Fri 03 Mar 17 @ 2:28 am
Already aware of this, and Dev Team is on it
Posted Fri 03 Mar 17 @ 6:57 am
are the tracks in spotify loading slow for anyone else
Posted Fri 03 Mar 17 @ 11:45 am
just created a deezer account to try the speeds there got a premium subscription. when i load onto either deck a track comes up with an error message.
Posted Fri 03 Mar 17 @ 12:11 pm
They load slow for everyone but apparently its not VDJ's fault ...... Good luck.
Posted Fri 03 Mar 17 @ 12:14 pm
Any ideas about the deezer error
Posted Fri 03 Mar 17 @ 12:31 pm
+10 for Duplicates filter
Posted Fri 03 Mar 17 @ 12:37 pm
i suppose the deezer loading error is because they are sorting out the problem regarding premium accounts
Posted Fri 03 Mar 17 @ 12:40 pm
