Forum: VirtualDJ Skins
Topic: [Wiki] SDK - Split panels
Posted Tue 07 Feb 17 @ 9:41 pm
Thank you!
thanks ;o)
Custom Browser Wiki page available https://virtualdj.com/wiki/Custom%20Browser.html
Just the bottom "more in Depth" part is missing for now, but will be offered soon.
PS. You may need to update your VirtualDJ to the latest Early Access build, as some features were added very recently.
Thanks, but some of the elements are still not working correctly.
i.e. when using sideview in its own dedicated skin area (not as part of the default browser) the 'sideview triggerpad' button which switches between pad view and grid(?) view doesn't function. The view doesn't change.
You can see this on V8 but by FRUiT. Use the automix/karaoke layout, select sampler in the sideview panel, then try to switch sampler views.
This bug has been there since VDJ 8 was released.
