When using custom mapping my hot cues will only trigger the last hot cue used. For example, I have hot_cue 5 mapped to a pad but when hitting that pad it will only play whichever hot cue was last used. It never triggers hot cue 5.
I have done several custom mapping in earlier versions of VDJ8 and VDJ7 without issue .
The only way I can get this to work is if I map using "pad 5" which would be fine if I only had 9 cues. But I have more than 8.
Possibly a bug?
Possibly a bug?
Posted Tue 24 Jan 17 @ 11:24 pm
hot_cue 12 as an example works perfectly here.
If you are remapping your keyboard remember to include deck: deck 1 hot_cue 12
If you are remapping a controller then you don't need to include a deck for most of the buttons unless you're trying to remap a "deckless" button
Perhaps you should give us more info to test better ?
Posted Wed 25 Jan 17 @ 12:15 am
