I would like to adjust the maximum volume for the volume faders on each channel. If it is now from 0-100, I would like to have it from 0-80.
How can I do that?
How can I do that?
Posted Sun 15 Jan 17 @ 4:51 am
param_bigger 0.8 ? level 0.8 : level
Posted Sun 15 Jan 17 @ 5:11 am
Is this to prevent clipping?
Posted Sun 15 Jan 17 @ 5:22 am
Thank you. Do I have to paste that into the mapping of the volume fader? Yes, it is to prevent clipping. I just want to have more headroom
Posted Sun 15 Jan 17 @ 7:35 am
Correct paste in mapping, but you would be better served turning your autogain setting down.
Posted Sun 15 Jan 17 @ 8:08 am
Lower your zerodB setting to -3dB or -6dB
Posted Sun 15 Jan 17 @ 12:26 pm
groovindj wrote :
Lower your zerodB setting to -3dB...
I agree. That works great for headroom
Posted Sun 15 Jan 17 @ 12:37 pm
mp3gain set the db at 89 all the headroom you need.
I also use Breakwawy dj to get the best sound while mixing.
Posted Sun 15 Jan 17 @ 12:57 pm
The option about zeroDB is great. That should work best :D Thank you very much!
Posted Sun 15 Jan 17 @ 1:19 pm
For explanation see here - the section on headroom.
Posted Sun 15 Jan 17 @ 1:31 pm
Posted Mon 16 Jan 17 @ 10:56 am
