Happy New Year all. I set a continuous loop in a track which is working fine. Here's the trouble, the Position Marker is continuing to move forward in the track, so when I release the loop the track does not continue to play where the loop left off but will continue playing "skipped ahead" in the track to where the Position Marker is currently at. Even when I stop the track the marker continues to move forward even until the end of the song. I never had this problem so I'm figuring I may have engaged or disengaged some feature. Thank you in advance for your help.
Posted Sun 08 Jan 17 @ 4:15 pm
You need to turn off "loop roll mode", right click on the little options ball to the right of the loop box.
Posted Sun 08 Jan 17 @ 8:05 pm
i did that too, Im having the same issue. loop roll didnt fix it. it was like the loops were short.
Posted Mon 09 Jan 17 @ 2:54 am
you've turned slip_mode on
Posted Mon 09 Jan 17 @ 3:40 am
Thank you locodog! I must have accidentally engaged "Slip Mode." Working fine now!
Posted Mon 09 Jan 17 @ 11:12 am
