i use my dj i/o on vdj 8 & it play only one channel on one side of speaker :( also it show on the mixer
Posted Sat 07 Jan 17 @ 4:20 pm
Not sure what you mean by "mixer", but f it's Hardware one, keep in mind that an Ext Mixer Audio configuration (with Deck 1, Deck 2, etc) requires an "analog mixer" license https://virtualdj.com/buy/
Home license allows only Master & Headphones audio configuration without any hardware/mixer used.
If that is not the case, make sure you you have the necesseray drivers (if available) and your sound card is set to Quadrophonic mode
https://virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html
Posted Sat 07 Jan 17 @ 11:37 pm
