Trying to hook up my arturia minilab mk2 to control virtual dj, but the controllers screen doesn't look like in the manual, and cant get the controller to work. any ideas?
Posted Wed 28 Dec 16 @ 11:25 pm
OK I had to Google that one. It's a music keyboard.
VDJ is DJ software. It supports DJ controllers, not music keyboards.
You could use it, yes (because it's MIDI) - but you'd have to map it yourself manually.
Posted Thu 29 Dec 16 @ 12:55 am
That's the idea, but it doesnt map correctly. It doesnt activate any of the things i map, even though it recognizes the knobs and the device. Any ideas?
Posted Sun 01 Jan 17 @ 10:35 pm
Posted Sun 01 Jan 17 @ 11:07 pm
