Hey... my American Audio wms 4.1 with vdj 7,4 is recording averything, regardless if the faders on both decks are at 0 and no audio i going out of "master" VDJ is recording it!? So when i want to mix, and starting i track on another deck, the volume on the deck is 0, VDJ record it anyway??? :(
What is going wrong? Need help!
Regards
Dannie aKa X-vida
Regards
Dannie aKa X-vida
Posted Tue 20 Dec 16 @ 12:13 pm
You need to connect the Booth Output of the VMS4 with the input of a different sound card and add Recordloopback to your ver7 audio Setup (Advanced mode)
https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
Posted Tue 20 Dec 16 @ 12:18 pm
Thanks Mate! :D
Posted Tue 20 Dec 16 @ 1:36 pm
Found out that if i set the default Recording device to "Line. 2-VMS4 AUDIO MIDI Device" in Windows and use Audacity for recording on that device, then you can spare the cable! :D
Posted Thu 22 Dec 16 @ 3:07 pm
