i have a numark mixtrak quad n virtual dj 8,i'm mapping than i like,but i have some problens with light effect, i put pads fx's n reset to be hotcue n when i press shift the fx's change to effects,but when effects are actived it only blink when shift is pressed, i wanna the blink every the effect is actived.
any know how?
here's code
<map value="FX1" action="var "delcue" ? delete_cue 1 : hot_cue 1" />
<map value="LED_FX_PAD1" action="var 'delcue' ? hot_cue 1 ? blink ? cue_color 1 : off : off : hot_cue 1 ? cue_color 1 : off" />
<map value="SHIFT_FX1" action="effect 1 active" />
<map value="SHIFT_LED_FX_PAD1" action="effect 1 active ? blink 500ms ? color '#8900ff' : color 'green' : color '#8900ff'" />
any know how?
here's code
Posted Fri 11 Nov 16 @ 8:22 pm
