I believe there is a cue point import bug.
Whenever Virtual DJ imports my cue points from Serato DJ, they are off slightly and do not sync properly with the beat grid.
Here's a video of what I'm talking about.
https://youtu.be/V-ZBCaXqZtI
I am showing this in Version 8.2b3510 but I believe this was happening in previous builds as well.
Any one else having this issue?
Posted Tue 08 Nov 16 @ 7:15 pm
That's a known "issue" (and not a bug) that can't be tweaked any further.
SeratoDj and VirtualDj use different ways to calculate time and store cue positions on their db's
When VirtualDj transforms the SeratoDj cues there's a round up "issue" on the math actions involved on the transformation formula. That's because with strictly mathematical terms, VirtualDj uses better accuracy and therefore there's a gap between each "position" transformed by Serato to VirtualDj time units. The actual cue place can be "anywhere" inside a small window which I believe is around 2ms.
When you import cues from Serato you should consider it as a "bonus" feature and then go ahead and tweak their position on VirtualDj.
Posted Wed 09 Nov 16 @ 1:07 pm
