Topic: Problems with current build
So I made the mistake of updating to the most current build last night before I had a gig and automix crashed every time songs changed from one to the other? Anyone else experiencing problems with the most current build?
Posted Tue 08 Nov 16 @ 12:58 am
No. I've just tested it, and Automix works fine for me in both the latest public release (b3394) and the latest early access release (b3510)
I'm on windows7
But that probably won't help you, so I suggest going back a build for your gig
You can get previous builds here: https://virtualdj.com/download/build.html
