How I can I set VDJ8 to play/loop a video file when playing audio only files? It seems that this operation has been removed or complicated from VDJ7.
Posted Sat 29 Oct 16 @ 6:56 pm
Put the video file into a folder
Open the FX GUI of the Slideshow Plugin (from Video Effects of the VIDEO panel ->Visualisations folder)
Click on the Select button to select the folder you have that video)
Enable the Video Effect button.
From VirtualDJ Settings->Options tab, select the Slideshow from the VideoAudioOnlyVisualisation setting's menu
Posted Sat 29 Oct 16 @ 8:34 pm
Thank you for the detailed response, perhaps a more simple way (return of the video sampler) would be beneficial in future.
Posted Sun 30 Oct 16 @ 3:36 am
